Hi, guys need help with power query transformation below is the raw data that need the output as 2nd table. Thanks in advance.
Raw data
Really fun challenge! You can make smart use of Splitter.SplitByCharacterTransition in this scenario.
Here's the alternative approach:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8kstV4hKTVTSUXLMSykC0eb65vpGBkamQKalvpEhiG0JZBuZGgBJQyMQYW4AYhsDRWJ1opW8EgsS84B8p8SsxCzcBhiCDTA2QRhgaGSsFBsLAA==", BinaryEncoding.Base64), Compression.Deflate)), {"ProjectRef", "ModelDataSet", "ProjectStart", "ProjectEnd", "FacilitiesUnitRate", "FacilitiesQuantity", "ServiceUnitRate", "ServiceQuantity"}),
// Sample binary data used for testing. Use the following line instead to get data from the table in the real implementation.
// Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content],
ChangeTypes = Table.TransformColumnTypes(Source,{{"ProjectRef", type text}, {"ModelDataSet", type text}, {"ProjectStart", type date}, {"ProjectEnd", type date}, {"FacilitiesUnitRate", Int64.Type}, {"FacilitiesQuantity", Int64.Type}, {"ServiceUnitRate", Int64.Type}, {"ServiceQuantity", Int64.Type}}, "en-US" ),
Unpivot = Table.UnpivotOtherColumns(ChangeTypes, {"ProjectRef", "ModelDataSet", "ProjectStart", "ProjectEnd"}, "Attribute", "Value"),
SplitAttribute = Table.SplitColumn(Unpivot, "Attribute", Splitter.SplitTextByCharacterTransition({"a".."z"}, {"A".."Z"} ), {"Category", "Attribute"}),
Pivot = Table.Pivot(SplitAttribute, List.Distinct(SplitAttribute[Attribute]), "Attribute", "Value", List.Sum),
#"Sorted Rows" = Table.Sort(Pivot,{{"ModelDataSet", Order.Ascending}, {"Category", Order.Ascending}})
#"Sorted Rows"
Thanks for prepping the initial dataset @smozgur
@ me in replies or I'll lose your thread
Master Power Query M? -> https://powerquery.how
Read in-depth articles? -> BI Gorilla
Youtube Channel: BI Gorilla
If this post helps, then please consider accepting it as the solution to help other members find it more quickly.
Testing your solution @Rickmaurinus. Looks interesting.
Edit: No, it is not interesting, it is beautiful! Thanks for posting it!
Another approach is, after unpivoting, group by the first five columns, and aggregate by pivoting each subtable
//Change next line to reflect actual data source
Source = Excel.CurrentWorkbook(){[Name="Table24"]}[Content],
//set data types
{"ProjectRef", type text}, {"ModelDataset", type text}, {"ProjectStart", type date},
{"ServiceQuantity", Int64.Type}}),
//Unpivot the Rate and Quantity columns
#"Unpivoted Columns" = Table.UnpivotOtherColumns(#"Changed Type",
{"ProjectRef", "ModelDataset", "ProjectStart", "ProjectEnd"}, "Attribute", "Value"),
//Split the Attribute Column retaining the first lower to upper case transition
// and label appropriately
#"Split Column by Character Transition" =
Table.SplitColumn(#"Unpivoted Columns", "Attribute",
Splitter.SplitTextByCharacterTransition({"a".."z"}, {"A".."Z"}),
//Group rows by the first five columns
#"Grouped Rows" = Table.Group(#"Split Column by Character Transition",
{"ProjectRef", "ModelDataset", "ProjectStart", "ProjectEnd", "Category"}, {
//Aggregate by pivoting each subgroup on the Attribute column
{"Aggregate", (t)=>Table.Pivot(t,List.Distinct(t[Attribute]), "Attribute","Value"),
type table[Unit=Currency.Type, Quantity=Int64.Type]}
//Expand the Tables column
#"Expanded Aggregate" = Table.ExpandTableColumn(#"Grouped Rows", "Aggregate", {"Unit", "Quantity"}, {"Unit Rate", "Quantity"})
I am very interested in seeing another way of doing this since I am not very good at using Pivot columns.
Until someone else comes up with a better approach, here is my way:
ChangeTypes = Table.TransformColumnTypes(Source,{{"ProjectRef", type text}, {"ModelDataSet", type text}, {"ProjectStart", type date}, {"ProjectEnd", type date}, {"FacilitiesUnitRate", Int64.Type}, {"FacilitiesQuantity", Int64.Type}, {"ServiceUnitRate", Int64.Type}, {"ServiceQuantity", Int64.Type}}),
UnpivotColumns = Table.Unpivot(ChangeTypes, {"FacilitiesUnitRate", "FacilitiesQuantity", "ServiceUnitRate", "ServiceQuantity"}, "Category", "Value"),
Quantity = Table.AddIndexColumn(Table.RenameColumns(Table.ReplaceValue(Table.SelectRows(UnpivotColumns, each Text.EndsWith([Category], "Quantity")),"Quantity","",Replacer.ReplaceText,{"Category"}), {{"Value", "Quantity"}}), "Index"),
UnitRate = Table.AddIndexColumn(Table.RenameColumns(Table.ReplaceValue(Table.SelectRows(UnpivotColumns, each Text.EndsWith([Category], "UnitRate")),"UnitRate","",Replacer.ReplaceText,{"Category"}), {{"Value", "Unit Rate"}}), "Index"),
JoinOnIndex = Table.NestedJoin(UnitRate, "Index", Quantity, "Index", "Join"),
ExpandQuantity = Table.ExpandTableColumn(JoinOnIndex, "Join", {"Quantity"}),
RemoveIndex = Table.RemoveColumns(ExpandQuantity,{"Index"})
RemoveIndex
AddCategoryColumn = Table.AddColumn(ChangeTypes, "Category", each {"Facilities", "Service"}),
ExpandCategory = Table.ExpandListColumn(AddCategoryColumn, "Category"),
AddRecordColumn = Table.AddColumn(ExpandCategory, "Custom", each
if [Category] = "Facilities" then [Rate = [FacilitiesUnitRate], Quantity = [FacilitiesQuantity]] else [Rate = [ServiceUnitRate], Quantity = [ServiceQuantity]]),
RemoveColumns = Table.RemoveColumns(AddRecordColumn,{"FacilitiesUnitRate", "FacilitiesQuantity", "ServiceUnitRate", "ServiceQuantity"}),
Result = Table.ExpandRecordColumn(RemoveColumns, "Custom", {"Rate", "Quantity"})
Result
Very nice!
