Hi
Can someone help me correct this:
= Table.AddColumn(#"Changed Type1", "Charge", if [Freight_Kind] = "ABC" and [Category] = "BBC" or "BBD" then 10.5 else 0)
error Im getting is:
Expression.Error: There is an unknown identifier. Did you use the [field] shorthand for a _[field] outside of an 'each' expression?
Thanks so much!
Then you should provide a sample...
or...
= Table.AddColumn(#"Changed Type1", "Charge", each if [Freight_Kind]="ABC" and ([Category]="BBC"or [Category]="BBD") then 10.5 else 0)
And you can play with parenthesis...
= Table.AddColumn(#"Changed Type1", "Charge", if [Freight_Kind] = "ABC" and [Category] = "BBC" or [Category]="BBD" then 10.5 else 0)
Thanks for your quick response but Im still getting the same error?
or...
Thats done it, thanks so much!
| 3 | |
| 3 | |
| 2 | |
| 2 | |
| 1 |
| 11 | |
| 9 | |
| 5 | |
| 4 |
