Help with correcting conditional column in Power Query
Hi
Can someone help me correct this:
= Table.AddColumn(#"Changed Type1", "Charge", if [Freight_Kind] = "ABC" and [Category] = "BBC" or "BBD" then 10.5 else 0)
error Im getting is:
Expression.Error: There is an unknown identifier. Did you use the [field] shorthand for a _[field] outside of an 'each' expression?
Thanks so much!
Then you should provide a sample...
or...
= Table.AddColumn(#"Changed Type1", "Charge", each if [Freight_Kind]="ABC" and ([Category]="BBC"or [Category]="BBD") then 10.5 else 0)
And you can play with parenthesis...
Jakinta
Solution Sage
Solution Sage
= Table.AddColumn(#"Changed Type1", "Charge", if [Freight_Kind] = "ABC" and [Category] = "BBC" or [Category]="BBD" then 10.5 else 0)
Thanks for your quick response but Im still getting the same error?
or...
Thats done it, thanks so much!
May Power BI Update Carousel
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
