Hopeisgood1
Resolver I
Resolver I
Data Type issue between Excel and Power BI
Hi
In excel - for the Incident ID, the data type is General
In Power BI, it's text.
I do not see a General data type in Power BI and the calculation I have such as SUM and it cannot use it as a string. If I use COUNT, it is all the same 😕
The dashboard is not doing this right at all.
Hi - I figured it out. I duplicated the column from Incident ID and did a split delimiter function to get rid of the INC. Then I renamed the duplicated column to INC Value and changed the datatype to whole number. I also updated the DAX code. That fixed the problem.
NOW I am trying to figure out the sort of Priority - UGH!!
Hi @Hopeisgood1 ,
You have characters in this column of data and Power BI is unable to recognize the column as a numeric type
Also this DAX of yours is a bit confusing, what exactly are you trying to calculate? Would you mind providing the sample data from your INC table and Age Groups table?
Dino Tao
PhilipTreacy
@Hopeisgood1
Change the data type in Power BI to Whole Number
Regards
Phil
Did I answer your question? Then please mark my post as the solution.
If I helped you, click on the Thumbs Up to give Kudos.
Blog :: YouTube Channel :: Connect on Linkedin
Hi.
I replied back in the first reply. I fixed the issue - please see my response 🙂
Thank you!
