Data Type issue between Excel and Power BI
Hi
In excel - for the Incident ID, the data type is General
In Power BI, it's text.
I do not see a General data type in Power BI and the calculation I have such as SUM and it cannot use it as a string. If I use COUNT, it is all the same 😕
The dashboard is not doing this right at all.
- Anonymous1 year ago
Hi - I figured it out. I duplicated the column from Incident ID and did a split delimiter function to get rid of the INC. Then I renamed the duplicated column to INC Value and changed the datatype to whole number. I also updated the DAX code. That fixed the problem.
NOW I am trying to figure out the sort of Priority - UGH!!
- PhilipTreacySuper User
Change the data type in Power BI to Whole Number
Regards
Phil
- AnonymousNot applicable
Hi.
I replied back in the first reply. I fixed the issue - please see my response 🙂
Thank you!
Hi Anonymous ,
You have characters in this column of data and Power BI is unable to recognize the column as a numeric typeAlso this DAX of yours is a bit confusing, what exactly are you trying to calculate? Would you mind providing the sample data from your INC table and Age Groups table?
Dino Tao- AnonymousNot applicable
