Hi!😉
I have table with dates and empty rows.
I need create Index column, based on dates's hierarchy (1...- earlier and to last date)
Thanks for help in advance!
Hi @Anonymous, for future requests - provide sample data in usable format please (not as a screenshot). If you don't know how to do it - read note below my post.
Result:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("lY/BCcAwCEV38ZzI19gFSgfoPUj336IeAqWpORTEw3s8xN4JUgGhQns9YpOXD4MwlBXaUtsYtrQNHHlYTVsbrWX2H9PBzmvFsHHMc+1tdfpjam38kbbkfgM=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [sbj_num = _t, name_id = _t, Date = _t]),
ChangedType = Table.TransformColumnTypes(Source,{{"Date", type date}}, "sk-SK"),
GroupedRows = Table.Group(ChangedType, {"sbj_num"}, {{"All", each
[ a = Table.Sort(Table.AddIndexColumn(_, "IndexHelper", 0, 1),{{"Date", Order.Ascending}}),
b = Table.AddIndexColumn(Table.SelectRows(a, (x)=> x[Date] <> null), "IndexHelper2", 1, 1),
c = Table.AddColumn(b, "Index", (x)=> if x[Date] <> null then x[IndexHelper2] else null, Int64.Type),
d = Table.NestedJoin(a, {"IndexHelper"}, c, {"IndexHelper"}, "H", JoinKind.LeftOuter),
e = Table.ExpandTableColumn(d, "H", {"Index"}, {"Index"}),
f = Table.RemoveColumns(Table.Sort(e, {{"IndexHelper", Order.Ascending}}), {"IndexHelper"})
][f], type table}}),
CombinedAll
cabn you provide pbix to solve
Result:
CombinedAll
Thanks a ton! It's working.🔥
I am very thankful for your kind help again)
and I appreciate your advice.
source = table_with_dates_and_empty_rows,
sort_index = Table.AddIndexColumn(source, "sort_index"),
fx = (tbl) =>
if tbl[Date]{0} = null
then tbl
else Table.AddIndexColumn(
Table.Sort(tbl, "Date"),
"Index",
1, 1
gr = Table.Group(
sort_index,
"Date",
{"x", fx},
GroupKind.Local,
(s, c) => Number.From(List.NonNullCount({s, c}) = 1 )
)[x],
combine = Table.Combine(gr),
sort_back = Table.Sort(combine, "sort_index")[[sbj_num], [name_id], [Date], [Index]]
sort_back
| 3 | |
| 2 | |
| 1 |
| 11 | |
| 11 | |
| 5 | |
| 4 |
