Did you hear? There's a new SQL AI Developer certification (DP-800). Start preparing now and be one of the first to get certified. Register now
Create Index Column based on Dates column in Power Query
Hi!😉
I have table with dates and empty rows.
I need create Index column, based on dates's hierarchy (1...- earlier and to last date)
Thanks for help in advance!
dufoq3
Hi @Anonymous, for future requests - provide sample data in usable format please (not as a screenshot). If you don't know how to do it - read note below my post.
Result:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("lY/BCcAwCEV38ZzI19gFSgfoPUj336IeAqWpORTEw3s8xN4JUgGhQns9YpOXD4MwlBXaUtsYtrQNHHlYTVsbrWX2H9PBzmvFsHHMc+1tdfpjam38kbbkfgM=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [sbj_num = _t, name_id = _t, Date = _t]),
    ChangedType = Table.TransformColumnTypes(Source,{{"Date", type date}}, "sk-SK"),
    GroupedRows = Table.Group(ChangedType, {"sbj_num"}, {{"All", each
        [ a = Table.Sort(Table.AddIndexColumn(_, "IndexHelper", 0, 1),{{"Date", Order.Ascending}}),
          b = Table.AddIndexColumn(Table.SelectRows(a, (x)=> x[Date] <> null), "IndexHelper2", 1, 1),
          c = Table.AddColumn(b, "Index", (x)=> if x[Date] <> null then x[IndexHelper2] else null, Int64.Type),
          d = Table.NestedJoin(a, {"IndexHelper"}, c, {"IndexHelper"}, "H", JoinKind.LeftOuter),
          e = Table.ExpandTableColumn(d, "H", {"Index"}, {"Index"}),
          f = Table.RemoveColumns(Table.Sort(e, {{"IndexHelper", Order.Ascending}}), {"IndexHelper"})
        ][f], type table}}),
    CombinedAll
cabn you provide pbix to solve
dufoq3
Result:
    CombinedAll
Thanks a ton! It's working.🔥
I am very thankful for your kind help again)
and I appreciate your advice.
AlienSx
    source = table_with_dates_and_empty_rows,
    sort_index = Table.AddIndexColumn(source, "sort_index"),
    fx = (tbl) =>
        if tbl[Date]{0} = null
            then tbl
            else Table.AddIndexColumn(
                Table.Sort(tbl, "Date"),
                "Index",
                1, 1
    gr = Table.Group(
        sort_index,
        "Date",
        {"x", fx},
        GroupKind.Local,
        (s, c) => Number.From(List.NonNullCount({s, c}) = 1 )
    )[x],
    combine = Table.Combine(gr),
    sort_back = Table.Sort(combine, "sort_index")[[sbj_num], [name_id], [Date], [Index]]
    sort_back
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
