Common Math problem: for calculating Fiscal Quarter Offset
I need help to use a M formula to calculate [Fiscal Qtr Offset], based on [Fiscal Mth].  Would really appreciate if you can help!
Fiscal yearFiscal MthFiscal Qtr Offset
F20191-5
 2-5
 3-5
 4-4
 5-4
 6-4
 7-3
 8-3
 9-3
 10-2
 11-2
 12-2
F20201-1
 2-1
 3-1
 40
 50
 60
 71
 81
 91
 102
 112
 122
F202113
 23
 33
 44
 54
 64
 75
 85
 95
 106
 116
 126
Thanks for the suggestion @v-frfei-msft
I have a much larger date table generated using PQ, so I was hoping to look for a PQ solution.
I was able to solve the issue - hope this will help others in the future:
= Number.RoundDown(((Date.Year([Date]) - Date.Year(CurrentDate)) * 12 + Date.Month([Date]) - Date.Month(CurrentDate)) / 3, 0)​
v-frfei-msft
Hi @Anonymous ,
We can achieve that by DAX.
offset = -6+CALCULATE(DISTINCTCOUNT('Table'[qtr]),FILTER(ALL('Table'),'Table'[Date]<=EARLIER('Table'[Date])))
Pbix as attached.
Community Support Team _ Frank
If this post helps, then please consider Accept it as the solution to help the others find it more quickly.
VasTg
Memorable Member
Memorable Member
@Anonymous
Need little more explanation on how you are generating Fiscal Qtr Offset? The Current quarter will always be -1?
Connect on LinkedIn
60 days of Data Days Carousel
Data Days 2026
