I have a table with 3 columns and I am bit confused with cleaning the data the dirty data is as follows:
Order ID category Amount
CA-2011-167199. Binders|Art. 5.4 | 31
CA-2011-149020. Tables|Binders. 17 |13
CA-2011-127614. Fasteners|Art. 6 | 3.6
After cleaning the data the data should look like this:
Order ID. Category. Amount
CA-2011-167199. Binders. 5.4
CA-2011-167199. Art. 31
CA-2011-149020. Tables. 17
CA-2011-149020. Binders 13
CA-2011-127614. Fasteners 6
CA-2011-127614. Art. 3.6
All suggestions are helpful thank you in advance
Hi @Anony_mous ,
How about this:
Before:
After:
Here the code in Power Query M that you can paste into the advanced editor (if you do not know, how to exactly do this, please check out this quick walkthrough)
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("Xcs7DoAgFETRrRhqJDwQySvRxBXYERs/iTYUqJ2Ld7QylidzJ0bRhtJoopJqT8xCimZL85L34ipCPmBXKw9YEoP85BVrozF3Z05PPG5pB41iwP1iS6wd1n6ZVszvB/TKQJVVyIcb", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Order ID" = _t, Category = _t, Amount = _t]),
#"Split Column by Delimiter 1" = Table.SplitColumn(Source, "Category", Splitter.SplitTextByDelimiter(" | ", QuoteStyle.Csv), {"Category", "Category.2"}),
#"Split Column by Delimiter 2" = Table.SplitColumn(#"Split Column by Delimiter 1", "Amount", Splitter.SplitTextByDelimiter(" | ", QuoteStyle.Csv), {"Amount", "Amount.2"}),
#"Removed Other Columns 1" = Table.SelectColumns(#"Split Column by Delimiter 2",{"Order ID", "Category.2", "Amount.2"}),
#"Renamed Columns" = Table.RenameColumns(#"Removed Other Columns 1",{{"Category.2", "Category"}, {"Amount.2", "Amount"}}),
#"Removed Other Columns 2" = Table.SelectColumns(#"Split Column by Delimiter 2",{"Order ID", "Category", "Amount"}),
#"Appended Query" = Table.Combine({#"Removed Other Columns 2", #"Renamed Columns"}),
#"Changed Type" = Table.TransformColumnTypes(#"Appended Query",{{"Amount", type number}})
#"Changed Type"
Let me know if this works for you 🙂
/Tom
https://www.tackytech.blog/
https://www.instagram.com/tackytechtom/
| Did I answer your question❓➡️ Please, mark my post as a solution ✔️ |
| Also happily accepting Kudos 🙂 |
| Feel free to connect with me on LinkedIn! | |
| #proudtobeasuperuser | |
Hi @Anony_mous ,
How about this:
Before:
After:
#"Changed Type"
/Tom
| 10 | |
| 6 | |
| 5 | |
| 5 | |
| 2 |
