I have another multiple "if statement" that I'm having issues with.
PKG.1_DATE1 =1/1/2020
PKG.1_DATE2 = 1/14/2020
PKG.2_DATE1 = 1/2/2020
PKG.2_DATE2 = 1/20/2020
This worked
Custom Column -> Latest Package Delay = if List.Max({[PKG.1_DATE2], [PKG.2_DATE2]}) = 0 then null else List.Max({[PKG.1_DATE2], [PKG.2_DATE2]})
This does not work
Custom Column -> Schedule Delay = if [Latest Package Date] = null then 0 else if [Latest Package Date] = [PKG.1_DATE2] then (Duration.Days [PKG.1_DATE2]-[PKG.1_DATE1])/7 else if [Latest Package Date] = [PKG.2_DATE2] then (Duration.Days [PKG.2_DATE2]-[PKG.2_DATE1])/7 else 0
Hi @Anonymous ,
Do you mean to calculate the difference with Duration.Days()? It should be "Duration.Days( [PKG.1_DATE2]-[PKG.1_DATE1] )/7"
@v-eachen-msft See message 5. I'm already using the Duration Days in my power query. I need to calculate the Duration Days from the latest package date.
Is the second custom column referencing the first one? Maybe just a typo in the post, but the names are different (Latest Package Date vs. Latest Package Delay).
If this works for you, please mark it as the solution. Kudos are appreciated too. Please let me know if not.
Pat
No, it should be Latest Package Date. This is not a problem. I need to find the difference in weeks from the latest package date.
if this
works, I suspect the column type [PKG.....] is not date.
Then the error that probably raises the following expression.
Could you give some example of the input table and the expected ouput table?
@Anonymous Thanks again for your help.
The expected output table for column "Schedule Delay" should be a value for the number of weeks delayed.
Input Table
and the input table is ...
you should give only some fictitious examples of the data you manage.
Is important know the number, the order and the name on the columns involved; the tipical case you wanto to treat:
For example if you have the max you are looking for in two differente pkg, which pkg we should considere to calculate the delay.
etc etc..
@Anonymous
Input Table
Date 2 for each package is a revised date. I want to pick the latest revised date and calculate the date difference (in weeks) between the revised date (date 2) and the initial planned date (date 1).
For example, in the input above the difference in PKG.1_Date2 and PKG.1_Date1 is 2. However, since PKG.2_Date2 is the furthest date out, I want to choose that as my baseline and calculate the date difference (in weeks) between the PKG.2_Date2 and PKG.2_Date1. Since there is nothing for PKG.3_Date1 and PKG.3_Date2 in this case, it will not impact the result. However, if there was a date for it, then it may impact the result.
