LuizKoller's avatar
LuizKoller
Resolver I
2 years ago
Help with Github In Power BI (using Visual Studio Code)
Hello! Im triyng to conect Power Bi in Github repo following this guide: https://learn.microsoft.com/en-us/power-bi/developer/projects/projects-git     However, its a little confusing. Could a...
  • RuiRomanoMS's avatar
    2 years ago
    Thanks for the feedback.
    For source control you should use the new Power BI Project (PBIP) format, that will let you save your Power BI file (PBIX) to a folder with metadata files as text (mostly JSON). You can then open the folder using VS Code and initialize a Git Repo for source control.
    Please see the following video where I demo end-to-end: https://youtu.be/OdkS7DF7ElY
