papi0506
Power query using variables in script blocks for POST API calls
Still new to power bi and it truly is a powerful tool. I'm running into one road block with my power query. The only way I've been able to make a proper POST API call to retreive data is by putting the Content of the Web.Contents body in a type of script block. This places quotes around the entire block for values to be taken as writen, but does not allow for they use of variables or parameters inside.
Example in the screenshot works perfect, but I need to be able to use parameters preferably that way values can be changed for the same call.
works like a charmworks like a charmwould like to use variables or parameters for dynamic valueswould like to use variables or parameters for dynamic values
The last screenshot, I've tried variables of different types and even parameters, but they break the syntax.
Any help is greatly appreciated.
AlB
Hi @papi0506
Try concatenating the string pieces rather than having everything in one string. Place the following M code in a blank query to see an example
    #"tryagain" = "GetInThere",
    BodyContent_=  "{ ""password"" : " & #"tryagain" & " }"
    BodyContent_
SU18_powerbi_badge
Please accept the solution when done and consider giving a thumbs up if posts are helpful.
AlB
Hi @papi0506
    BodyContent_
SU18_powerbi_badge
papi0506
Hey @AlB
Thank you so much, your suggestion worked like a charm. I had been looking for the proper syntax to all concatening strings together. This was exactly what I was looking for.
Vijay_A_Verma
Most Valuable Professional
Can you paste the query as text in this post so that experts can work on your query?
I'll keep that in mind for next time. AIB's suggestion worked perfectly and I can even use it with parameters now {yeaaaa}. Thank you very much tho.
