Dear all,
I'm a bit stuck on the power query editor.
I have a very small dataset with the product name, the process step, the process cost, and the process date.
I want to create a report per product name, per process step, and per month the cost.
I thought the PQE editor could automate the report.
I thought group by account, sum on cost. But I cant create further analysis, like totals per month. What is my mistake?
Dummy data see link.
https://www.dropbox.com/s/tdwfivd7cf0iwuv/test.xlsx?dl=0
Greetings.
@Anonymous
Your column names in the question are different from what is in the sample file. Anyhow, follow these steps.
1. Click on the Date Column, Under Add Column > Date > Month > End of Month.
2. Now group as follows:
Result:
⭕ Subscribe and learn Power BI from these videos
⚪ Website ⚪ LinkedIn ⚪ PBI User Group
Hi @Anonymous ,
After you get the end of month column, you can use 'Pivot column' to achieve this:
Reorder the column to show the result:
@Anonymous
Result:
Thx, how can see the costs per month
Apple 1 - January x February x march x
Apple 2 - January x February x march x
Apple 3 ...
Hi @Anonymous ,
@Anonymous
Like you added Date>Month>End of Month, you can add another two columns Year and Month Name from the same option then include these two columns instead of the End of The Month and Group.
| 2 | |
| 2 | |
| 2 | |
| 1 |
