Hi, I have 2 datasets "Evolution" and "Status" and I have a python script that makes some transformations using both of them. When I go to the Evolution data and Run Python script, by default the it is called dataset. What will be the name of Status if I want to call it in the same python script? or, What should I use to call both them in the same script?
Hi @Anonymous ,
Could you tell me if your problem has been solved?
If it is, kindly Accept it as the solution. More people will benefit from it.
Or you are still confused about it, please provide me with more details about your problem.
Stephen Tao
See this
One of my script I merge two existing queries with python statement
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i44FAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t]),
#"Run Python script" = Python.Execute("# Python:#(lf)import pandas as pd#(lf)df3 = pd.merge(df1, df2, how = 'left', on = ['Date'])",[df1=Table1, df2=Table])
