PamWren
Power Query Help required!
I have a dataset where the output shows employees and whether a reocord is locked or not.  Sme employees have both locked and not locked, ultimately showing 2 different rows for each.  I need to exclude any employee who has a no (even if they also have a yes).  I have included a screen shot, those highlighted in Yellow need to be excluded.  I can't remove duplicates as it doesnt remove in any order, i cant remove Yes for obvious reasons and removing no still leaves those yes's behind which need to be excluded.
An help would be gratefully received.
dufoq3
Hi @PamWren, check this:
Before
After
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bY85DoAwDAT/4jqFE5/5BD2KUlJT8H8JCkgMottdzVhya2AZhRgSrNsBPTVgRje/hmV/9wfwrKwWhoyoUv6G+0SpVbkGwAQJPwa5TWP0AYQcRZpOiPEf+cv9BA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"EE ID" = _t, Locked = _t]),
    GroupedRows = Table.Group(Source, {"EE ID"}, {{"All", each _, type table}, {"FilterHelper", each if List.ContainsAll([Locked], {"Yes", "No"}) then 0 else 1, Int64.Type}}),
    FilteredRows = Table.SelectRows(GroupedRows, each ([FilterHelper] = 1)),
    Combined = Table.Combine(FilteredRows[All])
    Combined
dufoq3
Before
After
    Combined
Thanks for your help - I actually found a fix myself over the weekend which worked beautifully.  But again thankyou.
May Power BI Update Carousel
Fabric SQL PBI Data Days
Data Days 2026 coming soon!
