chinthanar
Power BI tiles visuals not displaying properly in Power Point
I was created Dashboard and trying to add Power BI tiles to the Power Point slides, using "Power Bi Tiles" App. It was working fine earlier, but since last Friday tiles are not displaying the entire charts or visuals but only some of the text on title and “X” Axis can see.
@chinthanar,
When I pin live page to a dashboard and add the dashboard in Power Point, everything works well. but when I pin individual visuals to dashboard, I can reporduce your issue. Since the add-in is published by DEVSCOPE, I would recommend you contact Devscope support about this issue.
In addition, you can work around this issue by exporting report to powerpoint following the guide in this article.
Lydia
Thank you Lydia,
I was trying to pin live page and its working fine but Tile URL filter option is not working for live pages. Any workaround for this?
Chinthana
@chinthanar,
I have found no workaround for this issue, I would recommend you contact Devscope support about this issue.
Lydia
