Ashu27
Power BI formulas help
Hi Experts , we are building a powerBI dashboard for our data quality dashboard from the daily data quality reports out of Azure. We are doing extensive DQ checks such as null check, character validation check ,outlier check and so on. We need to show fields like total count,valid count,error count,error percentage, and we need these non additive fields to show in range of dates,let's says in between no of days, week, month and yearly total summaries. We are using formular such as
1.Error Percentage
Error_Percentage = DIVIDE( [Error_Count], [Total_Count], 0 ) * 100
2. Valid Percentage
Valid_Percentage = DIVIDE( [Valid_Count], [Total_Count], 0 ) * 100
3.Null Validation Metrics
Null_Error_Percentage = VAR NullErrors = CALCULATE( [Error_Count], DataQualityReport[Validation_Type] = "Null Validation" ) VAR NullTotal = CALCULATE( [Total_Count], DataQualityReport[Validation_Type] = "Null Validation" ) RETURN DIVIDE(NullErrors, NullTotal, 0) * 100 // Null check pass rate Null_Pass_Rate = 100 - [Null_Error_Percentage]
and similarly we are doing the same for character limit check etc. Please suggest is it the right approach or formulas are correct to give correct results.
bhanu_gautam
@Ashu27 Your approach to calculating error percentage, valid percentage, and null validation metrics using DAX formulas in Power BI seems correct. The formulas you provided are standard ways to calculate these metrics and are commonly used in data quality analysis
Did I answer your question? Mark my post as a solution! And Kudos are appreciated
LinkedIn
bhanu_gautam
LinkedIn
60 days of Data Days Carousel
Data Days 2026
