al1981
Helper II
Helper II
PQ Data model in Excel and in PBI does not give same info
I am pretty fresh, so please let me know what missed... Really sorry for this basic question, but...
I created model with unique event qurry with Column Event ID and another query of all speakers on all events - Speaker with name and one column with Event ID
When i create Pivot with Unique event in Rows and Speakers in Value, i get # off speakers, which is ok (number is correct), but there is not way i would be able to get names of speakers related to one particular event? I tried with slicer etc...
When i tested this same model with import to PBI, all works like a charm... What i missed?
Thank you!
al1981
Helper II
Helper II
Dear all
thank you! I did a huge mistake which I discovered just while converting to dummy data 🙂 PBI is a step ahead compared to Pivot Data model... I should double check things next time (beginners mistake)
al1981
Helper II
Helper II
Dear all
al1981
Helper II
Helper II
Hi @Anonymous
I will try ASAP, have real production data in, have to chage it somehow. Hope to come back ASAP
Can you share the file
