kcdavi01
POST API call using Power Query M - Help
Hi all,
Hope all is well! Im trying to connect to data via an API Post request. Im going through Power Query M to gather the data but fairly new at it.
My query looks like the below (XXX are replacing passwords/sensitivity) but I get the following error message:
Query:
Error Message:
Expression.Error: The 'Ocp-Apim-Subscription-Key' header is only supported when connecting anonymously. These headers can be used with all authentication types: Accept, Accept-Charset, Accept-Encoding, Accept-Language, Cache-Control, Content-Type, If-Modified-Since, Prefer, Range, Referer
Im I not entering the right query to run? How can I connect anonymously? Any help would be highly appreciated! Thanks in advance!
Hi @kcdavi01
If you have the related key, you can consider to select web connector when importing data.
Then click advanced , and refer to the following picture.
You can refer to the following link.
https://wisedatadecisions.com/2021/05/03/parameterize-an-api-request-in-power-query/
Best Regards!
Yolo Zhu
Hi Yolo Zhu,
I hope all is well! Thank you for providing that info! I did find it to be good knowledge!
However, it looks like this information is for API requests that use a GET function. I would like to use a POST function and I don’t think the traditional Web connector will work.
Im using Power Query M to write my POST request but ran into issues such as having to connect anonymously. Is this something you’ve encountered before?
Thanks in advance and appreciate your help!!
Best,
Kcdavi01
July Power BI Update Carousel
