I need help with a formula to show total capacity per day by individual service from the table below.
Basically I need the results to show exact total capacity number as shown in the data table below. Please note that the the below table itself is the data source.
Service Category | Hours Per Day | Capacity | Total Capacity Per Day |
Service 1 | 16 | 16 | 256 |
Service 2 | 16 | 3 | 48 |
Service 3 | 16 | 1 | 16 |
Service 4 | 16 | 2 | 32 |
Service 5 | 16 | 1 | 16 |
Service 6 | 16 | 3 | 48 |
Service 7 | 16 | 3 | 48 |
Service 8 | 16 | 2 | 32 |
Service 9 | 16 | 3 | 48 |
Service 10 | 16 | 8 | 128 |
Service 11 | 16 | 2 | 32 |
Service 12 | 16 | 2 | 32 |
Hi @AmeenVanakar ,
Try this. I have attached the file below. Thanks
Thanks! This worked.
Hi @AmeenVanakar ,
Hey @AmeenVanakar ,
You can calculate Total Capacity Per Day inside Power Query without using DAX. Since the total is simply the product of Hours Per Day and Capacity, follow these steps:
1. Load your data into Power Query.
2. Go to the Add Column tab and choose Custom Column.
3. In the formula field, type:
= [Hours Per Day] * [Capacity]
4. Give the column the name Total Capacity Per Day and confirm.
This will return the exact figures from your example for instance, if Hours Per Day = 16 and Capacity = 16, the total will be 256. If you prefer to do it directly in Excel after loading the data, you can add a column in the table and use:
=[@Hours Per Day] * [@Capacity]
Both methods will give the same outcome; using the Power Query approach ensures the calculation is part of your data transformation process.
If you found this solution helpful, please consider accepting it and giving it a kudos (Like) it’s greatly appreciated and helps others find the solution more easily.
Nasif Azam
Thanks for the help!
