AmeenVanakar
Advocate II
Advocate II
Need help with a measure in power query - excel
I need help with a formula to show total capacity per day by individual service from the table below.
Basically I need the results to show exact total capacity number as shown in the data table below. Please note that the the below table itself is the data source.
Service CategoryHours Per DayCapacityTotal Capacity Per Day
Service 11616256
Service 216348
Service 316116
Service 416232
Service 516116
Service 616348
Service 716348
Service 816232
Service 916348
Service 10168128
Service 1116232
Service 1216232
SundarRaj
Hi @AmeenVanakar ,
Try this. I have attached the file below. Thanks
Sundar Rajagopalan
AmeenVanakar
Advocate II
Advocate II
Thanks! This worked.
SundarRaj
Hi @AmeenVanakar ,
Sundar Rajagopalan
Nasif_Azam
Hey  @AmeenVanakar ,
You can calculate Total Capacity Per Day inside Power Query without using DAX. Since the total is simply the product of Hours Per Day and Capacity, follow these steps:
1. Load your data into Power Query.
2. Go to the Add Column tab and choose Custom Column.
3. In the formula field, type:
= [Hours Per Day] * [Capacity]
4. Give the column the name Total Capacity Per Day and confirm.
This will return the exact figures from your example for instance, if Hours Per Day = 16 and Capacity = 16, the total will be 256. If you prefer to do it directly in Excel after loading the data, you can add a column in the table and use:
=[@Hours Per Day] * [@Capacity]
Both methods will give the same outcome; using the Power Query approach ensures the calculation is part of your data transformation process.
If you found this solution helpful, please consider accepting it and giving it a kudos (Like) it’s greatly appreciated and helps others find the solution more easily.
Nasif Azam
Did I answer your question?
If so, mark my post as a solution!
Also consider helping someone else in the forums!
LinkedIn
Thanks for the help!
FabCon Global Hackathon
