Anonymous's avatar
6 years ago
Need Help with Conditional Column in Power BI-Power Query
I have these two statements in excel, but when I try to do in Power Query I keep getting errors.
1. =IF(IF([@[PT/NPT]]="PT",IF([@activity]="NONOPS","",[@DURATION]),IF(OR([@operation]="saftey",[@operation]="commute",[@operation]="lunch"),[@DURATION],""))="",0,IF([@[PT/NPT]]="PT",IF([@activity]="NONOPS","",[@DURATION]),IF(OR([@operation]="saftey",[@operation]="commute",[@operation]="lunch"),[@DURATION],"")))
2.=IF(IF([@[PT/NPT]]="NPT",IF(OR([@operation]="WOV_SDFN",[@operation]="WTHR",[@operation]="COMMUTE",[@operation]="LUNCH",[@operation]="SAFETY",[@operation]="SFTY MTG",[@operation]="WTHR/WIND",[@operation]="SFTY_ NPT", [@operation]="WOV_TRAV"),"",[@DURATION]),"")="",0,IF([@[PT/NPT]]="NPT",IF(OR([@operation]="WOV_SDFN",[@operation]="WTHR",[@operation]="COMMUTE",[@operation]="LUNCH",[@operation]="SAFETY",[@operation]="SFTY MTG",[@operation]="WTHR/WIND",[@operation]="SFTY_ NPT", [@operation]="WOV_TRAV"),"",[@DURATION]),""))
  • Hi Anonymous
    Formula1:
    Power query
    Creat two columns
    Custom=
    if [#"PT/NPT"] = "PT"
      then
         if [activity] = "NONOPS" then " " else [DURATION]       else
         if [operation] = "saftey" or [operation] = "commute" or [operation] = "lunch"
           then [DURATION] else " "
    Dax in a calcualted column
    b =
    IF (
        IF (
            [PT/NPT] = "PT",
            IF (
                [activity] = "NONOPS",
                [DURATION]
            IF (
                    || [operation] = "lunch",
                [DURATION],
        0,
        IF (
            [PT/NPT] = "PT",
            IF (
                [DURATION]
            IF (
                [DURATION],
    Maggie
    6 years ago
    This one worked
    if[activity]="NONOPS" and [#"PT/NPT"]="PT" then "0"
    else if ([operation]="safety" or [operation]="commute" or [operation]="lunch") then [DURATION] else [DURATION]
  • SteveCampbell's avatar
    SteveCampbell
    Icon for Memorable Member rankMemorable Member
    the syntax in Power Query is
    if [CONDITION] then {A} else if [CONDITION 2] then {B} else {C}
    to use OR statement, use a little case or / and between conditions
    if [CONDITION1] or [CONDITION2] then {A} else {B}
    if [CONDITION1] and [CONDITION2] then {A} else {B}
    Alternatively, you can add a conditional column
      This one worked
  • v-juanli-msft's avatar
    v-juanli-msft
    Hi Anonymous
    Formula1:
    Power query
    Creat two columns
    Custom=
      then
    b =
    IF (
        IF (
            [PT/NPT] = "PT",
            IF (
                [DURATION]
            IF (
                [DURATION],
        0,
        IF (
            [PT/NPT] = "PT",
            IF (
                [DURATION]
            IF (
                [DURATION],
    Maggie
      This one worked too!  Thank you for your help!
