I have these two statements in excel, but when I try to do in Power Query I keep getting errors.
1. =IF(IF([@[PT/NPT]]="PT",IF([@activity]="NONOPS","",[@DURATION]),IF(OR([@operation]="saftey",[@operation]="commute",[@operation]="lunch"),[@DURATION],""))="",0,IF([@[PT/NPT]]="PT",IF([@activity]="NONOPS","",[@DURATION]),IF(OR([@operation]="saftey",[@operation]="commute",[@operation]="lunch"),[@DURATION],"")))
2.=IF(IF([@[PT/NPT]]="NPT",IF(OR([@operation]="WOV_SDFN",[@operation]="WTHR",[@operation]="COMMUTE",[@operation]="LUNCH",[@operation]="SAFETY",[@operation]="SFTY MTG",[@operation]="WTHR/WIND",[@operation]="SFTY_ NPT", [@operation]="WOV_TRAV"),"",[@DURATION]),"")="",0,IF([@[PT/NPT]]="NPT",IF(OR([@operation]="WOV_SDFN",[@operation]="WTHR",[@operation]="COMMUTE",[@operation]="LUNCH",[@operation]="SAFETY",[@operation]="SFTY MTG",[@operation]="WTHR/WIND",[@operation]="SFTY_ NPT", [@operation]="WOV_TRAV"),"",[@DURATION]),""))
Hi @chel4782
Formula1:
Power query
Creat two columns
Custom=
if [#"PT/NPT"] = "PT"
then
if [activity] = "NONOPS" then " " else [DURATION] else
if [operation] = "saftey" or [operation] = "commute" or [operation] = "lunch"
then [DURATION] else " "
Dax in a calcualted column
b =
IF (
IF (
[PT/NPT] = "PT",
IF (
[activity] = "NONOPS",
[DURATION]
IF (
|| [operation] = "lunch",
[DURATION],
0,
IF (
[PT/NPT] = "PT",
IF (
[DURATION]
IF (
[DURATION],
Maggie
This one worked
if[activity]="NONOPS" and [#"PT/NPT"]="PT" then "0"
else if ([operation]="safety" or [operation]="commute" or [operation]="lunch") then [DURATION] else [DURATION]
Hi @chel4782
Formula1:
Power query
Creat two columns
Custom=
then
b =
IF (
IF (
[PT/NPT] = "PT",
IF (
[DURATION]
IF (
[DURATION],
0,
IF (
[PT/NPT] = "PT",
IF (
[DURATION]
IF (
[DURATION],
Maggie
This one worked too! Thank you for your help!
the syntax in Power Query is
if [CONDITION] then {A} else if [CONDITION 2] then {B} else {C}
to use OR statement, use a little case or / and between conditions
if [CONDITION1] or [CONDITION2] then {A} else {B}
if [CONDITION1] and [CONDITION2] then {A} else {B}
Alternatively, you can add a conditional column
Did I answer your question? Mark my post as a solution! Proud to be a Super User!
Connect with me!
Stay up to date on
Read my blogs on
This one worked
| 2 | |
| 2 | |
| 2 | |
| 1 |
