suneelkethagani's avatar
suneelkethagani
3 years ago
Need Dates in Same Row for Each Project in Power Query
Hi Guys,
This is my data in Power Query.
Project ID    Status    Status1Date    Status2Date    Status3Date    Status4Date
1                  Status1    1/1/2022
2                  Status1    2/5/2022
3                  Status2                          5/5/2022
4                  Status3                                                 3/23/2022
5                  Status4        7/11/2022
1                  Status2                          3/3/2022
1                  Status3                                                   5/6/2022
3                  Status4        8/3/2022
I need output like the below...
1                  Status1    1/1/2022      3/3/2022         5/6/2022
2                  Status1    2/5/2022
3                  Status2                          5/5/2022                                8/3/2022
4                  Status3                                                 3/23/2022
5                  Status4        7/11/2022
Here I have used Group By of "Project ID" and have taken min of all statuses dates. I am getting correct result.
But Sometimes I may be back to the previous status like
1                  Status1    1/1/2022
2                  Status1    2/5/2022
3                  Status2                          5/5/2022
4                  Status3                                                 3/23/2022
5                  Status4        7/11/2022
1                  Status2                          3/3/2022
1                  Status3                                                   5/6/2022
3                  Status4        8/3/2022
1                  Status2                           8/8/2022
In this case I need this column also need to show in the final table like
1                  Status1     1/1/2022     8/8/2022         5/6/2022
2                  Status1    2/5/2022
4                  Status3                                                 3/23/2022
5                  Status4        7/11/2022
How can I get it in Power Query?
Could you please help me?
Suneel K.
1 Reply
  • Hi suneelkethagani ,
    Paste the following code into a new blank query using Advanced Editor to see the steps I took:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bY5bDoAgDATvwjcJfYByF8L9r+HWVLRqUpKW6U46RuKUz0dcUEIiGLxmHkkuLoXaD1c0/gUeV4xXNLoiooV0rRhvaOqthGUv7IcY54c/hD3PwW8nbMGvH39flrcfpAf/PAA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Project ID" = _t, Status = _t, Status1Date = _t, Status2Date = _t, Status3Date = _t, Status4Date = _t]),
        chgTypes = Table.TransformColumnTypes(Source,{{"Project ID", Int64.Type}, {"Status", Int64.Type}, {"Status1Date", type date}, {"Status2Date", type date}, {"Status3Date", type date}, {"Status4Date", type date}}),
        remStatusCol = Table.RemoveColumns(chgTypes,{"Status"}),
        groupProjectID = Table.Group(remStatusCol, {"Project ID"}, {{"data", each _, type table [Project ID=nullable number, Status=nullable number, Status1Date=nullable date, Status2Date=nullable date, Status3Date=nullable date, Status4Date=nullable date]}}),
        fillDownNested = Table.TransformColumns(groupProjectID, {"data", each Table.FillDown(_, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"})}),
        fillUpNested = Table.TransformColumns(fillDownNested, {"data", each Table.FillUp(_, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"})}),
        nestedTableDistinct = Table.TransformColumns(fillUpNested, {"data", each Table.Distinct(_)}),
        expandDataCol = Table.ExpandTableColumn(nestedTableDistinct, "data", {"Status1Date", "Status2Date", "Status3Date", "Status4Date"}, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"})
        expandDataCol
    STEP SUMMARY:
    remStatusCol = Remove the status column as no longer required
    groupProjectID = Group table on [Project ID] and use an 'All Rows' aggregation to create nested project tables
    fillDownNested/fillUpNested = just fill all cells in nested tables with dates
    nestedTableDistinct = Remove all duplicate rows from nested tables
    expandDataCol = Reinstate nested table columns to the main table
    I get the following output:
    Pete
