Need Dates in Same Row for Each Project in Power Query
Hi Guys,
This is my data in Power Query.
Project ID Status Status1Date Status2Date Status3Date Status4Date
1 Status1 1/1/2022
2 Status1 2/5/2022
3 Status2 5/5/2022
4 Status3 3/23/2022
5 Status4 7/11/2022
1 Status2 3/3/2022
1 Status3 5/6/2022
3 Status4 8/3/2022
I need output like the below...
1 Status1 1/1/2022 3/3/2022 5/6/2022
2 Status1 2/5/2022
3 Status2 5/5/2022 8/3/2022
4 Status3 3/23/2022
5 Status4 7/11/2022
Here I have used Group By of "Project ID" and have taken min of all statuses dates. I am getting correct result.
But Sometimes I may be back to the previous status like
1 Status1 1/1/2022
2 Status1 2/5/2022
3 Status2 5/5/2022
4 Status3 3/23/2022
5 Status4 7/11/2022
1 Status2 3/3/2022
1 Status3 5/6/2022
3 Status4 8/3/2022
1 Status2 8/8/2022
In this case I need this column also need to show in the final table like
1 Status1 1/1/2022 8/8/2022 5/6/2022
2 Status1 2/5/2022
4 Status3 3/23/2022
5 Status4 7/11/2022
How can I get it in Power Query?
Could you please help me?
Suneel K.
1 Reply
- BA_Pete
Hi suneelkethagani ,
Paste the following code into a new blank query using Advanced Editor to see the steps I took:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("bY5bDoAgDATvwjcJfYByF8L9r+HWVLRqUpKW6U46RuKUz0dcUEIiGLxmHkkuLoXaD1c0/gUeV4xXNLoiooV0rRhvaOqthGUv7IcY54c/hD3PwW8nbMGvH39flrcfpAf/PAA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Project ID" = _t, Status = _t, Status1Date = _t, Status2Date = _t, Status3Date = _t, Status4Date = _t]), chgTypes = Table.TransformColumnTypes(Source,{{"Project ID", Int64.Type}, {"Status", Int64.Type}, {"Status1Date", type date}, {"Status2Date", type date}, {"Status3Date", type date}, {"Status4Date", type date}}), remStatusCol = Table.RemoveColumns(chgTypes,{"Status"}), groupProjectID = Table.Group(remStatusCol, {"Project ID"}, {{"data", each _, type table [Project ID=nullable number, Status=nullable number, Status1Date=nullable date, Status2Date=nullable date, Status3Date=nullable date, Status4Date=nullable date]}}), fillDownNested = Table.TransformColumns(groupProjectID, {"data", each Table.FillDown(_, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"})}), fillUpNested = Table.TransformColumns(fillDownNested, {"data", each Table.FillUp(_, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"})}), nestedTableDistinct = Table.TransformColumns(fillUpNested, {"data", each Table.Distinct(_)}), expandDataCol = Table.ExpandTableColumn(nestedTableDistinct, "data", {"Status1Date", "Status2Date", "Status3Date", "Status4Date"}, {"Status1Date", "Status2Date", "Status3Date", "Status4Date"}) in expandDataColSTEP SUMMARY:
remStatusCol = Remove the status column as no longer required
groupProjectID = Group table on [Project ID] and use an 'All Rows' aggregation to create nested project tables
fillDownNested/fillUpNested = just fill all cells in nested tables with dates
nestedTableDistinct = Remove all duplicate rows from nested tables
expandDataCol = Reinstate nested table columns to the main table
I get the following output:
Pete
