Hi!
Is it possible to get data using a parameter and calling a Function in Oracle? It seems to work for SQL Server.
I have tried to call the function with a hard coded inparameter in it works fine.
Source = Oracle.Database("xxx", [HierarchicalNavigation=true, Query="SELECT * FROM TABLE ( pipeStockWeek (202201))"]),
SourceBut when i try to use a parmeter:
WeekNo = ConvertToIntgr (RangeStart),
Source = Oracle.Database("uburr", [HierarchicalNavigation=true, Query="SELECT * FROM TABLE ( pipeStockWeek (WeekNo))"]),
SourceThen I get this error message:
DataSource.Error: Oracle: ORA-00904: "WEEKNO": invalid identifier
Details:
DataSourceKind=Oracle
DataSourcePath=uburr
Message=ORA-00904: "WEEKNO": invalid identifier
ErrorCode=-2147467259
Regards
Fredrik
Hi @FredrikJ ,
According to the error message, please see if this document helps: ORA-00904 invalid identifier Solution - Database
Community Support Team _ kalyj
Hi!
The document didn't help me. I wasn't really the same case.
My question is if it is supported and possible using a parameter from power query and calling a Function in Oracle to get data?
Regards
Fredrik
| 6 | |
| 3 | |
| 2 | |
| 2 |
| 11 | |
| 10 | |
| 8 | |
| 7 | |
| 7 |
