akhaliq7
Post Prodigy
Post Prodigy
Implementing SQL query parameters in Power BI/Power Query
Problem
I have been given a sql query which has two parameters called start_date and end_date, need to show the exact same data in power bi.
Current Methods to import data
I currently create a sql view and import it, don't have any experience using parameters.
Background
I am importing the previous 5 years of data using hardcoded values instead of parameters But as the query is really complicated as it is using unions, where in and where not in and the date filter is in multiple queries I know this method will not return the correct  number of rows.  Therefore my current method will not work instead need to use parameters.
With the limited information given even if someone can either guide me as to there process when dealing with parameters in sql and implementing the same in power query/power bi or even share a link etc.
OwenAuger
Hi @akhaliq7
One idea: Create a table-valued function, then query this function using the Power Query interface.
Here's a table-valued function I created to test:
CREATE OR ALTER FUNCTION DateTable (
	@StartDate DATE
	,@EndDate DATE
RETURNS TABLE
AS
SELECT [FullDateAlternateKey], [CalendarYear], [MonthNumberOfYear]
FROM [AdventureWorksDW].[dbo].[DimDate]
WHERE [FullDateAlternateKey] BETWEEN @StartDate AND @EndDate
Then in Power Query, you connect to this function, which is exposed as a Power Query function, and populate the parameters using whatever means you like:
Would something like this work for you?
Regards
Owen Auger
Blog
LinkedIn
OwenAuger
Hi @akhaliq7
	@StartDate DATE
	,@EndDate DATE
RETURNS TABLE
AS
Regards
Owen Auger
Blog
LinkedIn
