CHARLEA1
Identifying Duplicates and Ranking using Power Query
Hi there,
I've spent a long time searching the internet and have only found forumns on how to accomplish this via DAX, although I need a solution on Power Query as I intend to pivot the table depending on the custom column results.
I'm looking for how I can count a duplicate value and rank it as 1,2,3,... in the other column with Power Query
Eg.
Name           new column
jame1
jon1
jame2
jame3
jon2
jame4
jon3
Any help would be much appreciated!
Ashling
jennratten
Hello - you can accomplish this by: grouping > add an index for each row > add another index to the grouped table in each row > expand.
SCRIPT:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45W8srPyFOK1UFiBCcWJeJg+JQmV6IxMnNygKxYAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Names = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Names", type text}}),
    #"Grouped Rows" = Table.Group(#"Changed Type", {"Names"}, {{"Data", each _, type table [Names=nullable text, Index=number]}}),
    #"Added Index" = Table.AddIndexColumn(#"Grouped Rows", "Index", 1, 1, Int64.Type),
    #"Added Custom" = Table.AddColumn(#"Added Index", "Subtable", each Table.AddIndexColumn ([Data], "Index2", 1, 1, Int64.Type )),
    #"Removed Other Columns" = Table.SelectColumns(#"Added Custom",{"Subtable", "Index"}),
    #"Expanded Subtable" = Table.ExpandTableColumn(#"Removed Other Columns", "Subtable", {"Names", "Index2"}, {"Names", "Index2"})
wdx223_Daniel
NewStep=Table.FromRecords(List.Accumulate(Table.ToRecords(PreviousStepName),{{},[]},(x,y)=>let a=Record.TransformFields(x{1},{y[Name],each _+1??1}) in {x{0}&{y&[Count=Record.Field(a,y[Name])]}},a}){0})
jennratten
SCRIPT:
July Power BI Update Carousel
60 days of Data Days Carousel
Data Days 2026
