IfaZ_1
How to do if else function in power query using boolean and decimal
I need help to achieve 2 main goals with this data.
1. To get the espected result column
2. To remove the duplication for ID that have both expected result (Verified & Self Score) by keeping the expected result = Verified (priority)
This is my code Im usinh, however it gave me Self Score only as the outcome.
Here is my sample file : https://we.tl/t-ALEtPdEbgs
IfaZ_1
Hi Nate
changed it but it doesnt work
Try = null instead of = "null".
--Nate
