ND_Pard
Helper II
Helper II
Help with using an SQL statement in Power Query to extract data from an Excel workboook
Currrently the M Language in a Power Query that extracts data from a workbook looks like:
Source = Excel.Workbook(File.Contents("P:\So Fiscal Administration\Cost Centers\PeopleSoft_Accounts_SAMIS_Object_Codes.xls"), null, true),
Acct_Codes1 = Source{[Name="Acct_Codes"]}[Data]
Acct_Codes1
How would I change the above if I wanted to use an SQL statement like the following to extract the data:
Select Acct, Acct_Descr from Acct_Codes
Note: I know I could use the former code and then remove other columns, but I'm curious if I can use the latter code; i.e., can I use an SQL select statement in the top code?
Thanks in advance..
smpa01
@ND_Pard there is a way. If you have premium workspace, bring your data to datamart and the world of SQL is open to you.
Proud to be a Super User
My Custom Visualization Projects
• Plotting Live Sound: Live Sound
• Beautiful News: Women in Parliament, Energy Mix, Shrinking Armies
• Visual Capitalist: Working Hrs
• Others: Easing Graph, Animated Calendar
MayViz Submissions
• Week 1: View
• Week 2: View
• Week 3: View
• Week 4: View
StefanoGrimaldi
Resident Rockstar
Resident Rockstar
you cant use sql statement on a excel data extraction.
Did I answer your question? Mark my post as a solution! / Did it help? Give some Kudos!
60 days of Data Days Carousel
Data Days 2026
