Anonymous's avatar
6 years ago
Help creating dynamic parameters for power query
Hi all,
Need help in creating a dynamic parameter to my query in power bi query as below:
(dtquery as text) =>
url="https://<instance>.xxx.com/api/now/table/incident?sysparm_display_value=true&sysparm_exclude_reference_link=true&sysparm_limit=1&sysparm_query=sys_created_onSTARTSWITH2020-07-08",
Source = Json.Document(Web.Contents(url,[Query=sysparm_query&"="&sys_created_on&STARTSWITH&dtquery]))
But I am getting this error :
An error occurred in the ‘’ query. Expression.Error: The name 'sysparm_query' wasn't recognized. Make sure it's spelled correctly.
Not sure what am I doing wrong here
  • Mariusz's avatar
    Mariusz
    Hi Anonymous
    So there is a clear indication that the below part is wrong.
    most probably you have not defined sysparm_query anywrer in power query.
    Mariusz
    If this post helps, then please consider Accepting it as the solution.
    Please feel free to connect with me.
    LinkedIn
      Mariusz Thanks for your reply, But if you see my URL I am actually using the parameter in the query:
