Help creating dynamic parameters for power query
Hi all,
Need help in creating a dynamic parameter to my query in power bi query as below:
(dtquery as text) =>
url="https://<instance>.xxx.com/api/now/table/incident?sysparm_display_value=true&sysparm_exclude_reference_link=true&sysparm_limit=1&sysparm_query=sys_created_onSTARTSWITH2020-07-08",
Source = Json.Document(Web.Contents(url,[Query=sysparm_query&"="&sys_created_on&STARTSWITH&dtquery]))
But I am getting this error :
An error occurred in the ‘’ query. Expression.Error: The name 'sysparm_query' wasn't recognized. Make sure it's spelled correctly.
Not sure what am I doing wrong here
Mariusz
Hi @Anonymous
So there is a clear indication that the below part is wrong.
most probably you have not defined sysparm_query anywrer in power query.
Mariusz
If this post helps, then please consider Accepting it as the solution.
Please feel free to connect with me.
LinkedIn
@Mariusz Thanks for your reply, But if you see my URL I am actually using the parameter in the query:
July Power BI Update Carousel
