rajpal_singh
Extract numbers from a string column in excel using power query
Hi Community,
Can someone please help?
How can I extract the numbers from the string in Excel or CSV files using Power Query.
Like in the example below:
Thanks for your help in advance.
2 ACCEPTED SOLUTIONS
AlienSx
Splitter.SplitTextByWhitespace()(Text.Trim(Text.Select(your_text, {" ", "0".."9"})))
Omid_Motamedise
use this formula (I have split it into several steps to be more clear)
    Source = Table.FromColumns({{"This is a 500 of 600", "800 of 558 available", "order has 60 of 20"}},{"Description"}),
    #"Added Custom" = Table.AddColumn(Source, "S1", each Text.Split([Description]," ")),
    #"Added Custom1" = Table.AddColumn(#"Added Custom", "S2", each List.Transform([S1], each try Number.From(_) otherwise null)),
    #"Added Custom2" = Table.AddColumn(#"Added Custom1", "S3", each List.RemoveNulls([S2])),
    #"Added Custom3" = Table.AddColumn(#"Added Custom2", "Custom", each Record.FromList([S3],{"column 1"," column 2"})),
    #"Expanded Custom" = Table.ExpandRecordColumn(#"Added Custom3", "Custom", {"column 1", " column 2"}, {"column 1", " column 2"})
    #"Expanded Custom"
If my answer helped solve your issue, please consider marking it as the accepted solution.
Omid_Motamedise
    #"Expanded Custom"
AlienSx
Greg_Deckler
@rajpal_singh Can you post that sample data as text? Seems like you could split the column based on " of " perhaps and go from there.
Follow on LinkedIn
External Tools: MSHGQM
Latest book!:
DAX For Humans
