Anonymous's avatar
3 years ago
Extract domain parts
hello all, I am trying to extract Domain and sub domain, so far this M query,
let splitUrlandTitle = Splitter.SplitTextByDelimiter("/", QuoteStyle.None)([UrlandTitle]), splitsplitUrlandTitle2 = List.Reverse(Splitter.SplitTextByDelimiter(".", QuoteStyle.None)(splitUrlandTitle{2}?)) in splitsplitUrlandTitle2{2}?
gives the best result, it returns "lemoncity" but does not work on url's without a leading "/". I have url's like
https://desktop.lemoncity.ca.gov
http://desktop.lemoncity.ca.gov
lemoncity.ca.gov/more/more
lemoncity.ca.gov:404
Is there a way to insert a condition where if the text does not contain "/" then extract using another method?
thanks
  • Does your text always contain ca.gov as the domain extension? If yes, below will work.
    (But if your code contains various other domain extensions also, then we will need to think about other strategy)
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WyigpKSi20tdPSS3OLskv0MtJzc3PS84sqdRLTtRLzy9TitWBKCKkBq8kuqB+bn5RKpjAKm1lYmACtxif69DMgSnHpywWAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [UrlandTitle = _t]),
        #"Added Custom" = Table.AddColumn(Source, "Domain Name", each List.Last(Text.SplitAny(Text.BeforeDelimiter([UrlandTitle], ".ca.gov"), "./"))),
        #"Added Custom1" = Table.AddColumn(#"Added Custom", "Sub Domain Name", each List.Last(List.RemoveLastN(Text.Split(Text.AfterDelimiter(Text.BeforeDelimiter(if Text.Contains([UrlandTitle],"//") then [UrlandTitle] else "//" & [UrlandTitle], ".ca.gov"), "//"), "."), 1)))
        #"Added Custom1"
  • Vijay_A_Verma's avatar
    Vijay_A_Verma
    Most Valuable Professional
        #"Added Custom1"
      Thank you for the M, I am getting great results, there are a few where the extract in not happening but in similar strings the extract is happening? like these stings below from the title column
      Anonymous OMG Name on "omg.ca.gov"
      Session Obsession on "workinfo.workinginfo.ca.gov"
      Open reversal Blahblah on somecity.ca.gov
      Open reversal on oops.ca.gov
      OEM Misunderstanding at oops.ca.gov
      Thanks for the help
        Vijay_A_Verma
        Use this
            Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("hZAxC4MwEIX/SnAusYOTWwulk3XoqA5RryqaXPCixX9fjbagFB0SHnnfyzsuipzSGE2+6+ZAtUHNG5CossoMPBO8wN5JTjN0xOya20dXYgv2+mv73tn7Fe9Nt/nnix9gF4VqkNgRC4M7ewgJDBWLHZTFEogdCz6BqBqtMKVFWe6NbV2pF/JZFFavgqEGxVrooSXRsGsjynQ8U5pQwnY7a3pqQU0r4BawoKJO5SNihMrHUibMmks+", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [UrlandTitle = _t]),
            #"Added Custom" = Table.AddColumn(Source, "Domain Name", each [a = List.Last(Text.Split([UrlandTitle]," ")), b=List.Last(Text.SplitAny(Text.BeforeDelimiter(Text.Replace(a,"""",""), ".ca.gov"), "./"))][b]),
            #"Added Custom1" = Table.AddColumn(#"Added Custom", "Sub Domain Name", each [a = List.Last(Text.Split([UrlandTitle]," ")), b=List.Last(List.RemoveLastN(Text.Split(Text.AfterDelimiter(Text.BeforeDelimiter(Text.Replace(if Text.Contains(a,"//") then a else "//" & a,"""",""), ".ca.gov"), "//"), "."), 1))][b])
            #"Added Custom1"
