v-likosh
Error while using SQL queries in Power BI
Following query works fine within cosmosDB:
SELECT
COUNT(1) AS dcount_ip, c.AlertType, c.SubscriptionId, c.BinByDay
FROM(
SELECT
DISTINCT a.AlertObject.Metadata.cip AS d_cip,
a.AlertObject.AlertType,
a.AlertObject.ExtendedProperties.SubscriptionId,
DateTimeBin(a.ProcessingEndTimeUtc,'day') AS BinByDay
FROM Alert a
WHERE a.IsValidAlert = true) c
GROUP BY c.AlertType, c.SubscriptionId, c.BinByDay
However, when I am submitting this query through PoerBI SQL box at the time of fetching the data, it is failing.
Error message:
DataSource.Error: Cross partition query only supports 'VALUE <AggregateFunc>' for aggregates.
Uspace87
Resolver III
Resolver III
Try to use Value Count(1) as per below:
SELECT
Value COUNT(1) AS dcount_ip, c.AlertType, c.SubscriptionId, c.BinByDay
FROM(
SELECT
FROM Alert a
Hello @Uspace87 ,
The above code did not help in resolving the error and I still get the same error.
v-yanjiang-msft
Hi @v-likosh ,
Please see if the solution in the below similar thread can help:
DocumentDb error "Cross partition query only supports 'VALUE <AggreateFunc>' for aggregates" - Stack...
DocumentDb error Cross partition query only supports VALUE AggreateFunc for aggregates - SQL - YouTu...
Community Support Team _ kalyj
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Hello @v-yanjiang-msft ,
The provided solution did not work in my case.
July Power BI Update Carousel
