Register now!Learn from the best! Meet the four finalists headed to the FINALS of the Power BI Dataviz World Championships! Register now
Hi All
I have below formula embedded in my PBIX file to restrict by 2 months worth of data. It works fine when the data loads from Cloudera Impala. However, it doesn't work when the connection is repointed to Azure Synapse- basically the data loads everything when I click refresh. Anyone can help? Thank you.
#"Filtered Rows" = Table.SelectRows(Table,
each ([calmonth] = List.Max(Table[calmonth]) or [calmonth] = List.Max(Table[calmonth])-1)),
#"Kept Errors" = Table.SelectRowsWithErrors(#"Filtered Rows")
#"Kept Errors"
Hi @Mimi_Ibrahim ,
Please check this similar post:
Solved: Error When Using Power Query to Restrict Data - Microsoft Power BI Community
Stephen Tao
Hi @Mimi_Ibrahim ,
Try the following.
= Table.SelectRows(#"Changed Type", each [calmonth] = List.Max(#"Changed Type"[calmonth]) or [calmonth] = List.Max(#"Changed Type"[calmonth])-1 )
Stephen Tao
Hi @Anonymous ,
The link you provided is from my other post which is a different issue. This post if for different issue.
Hi @Mimi_Ibrahim ,
Try the following.
Stephen Tao
Hi @Mimi_Ibrahim ,
Stephen Tao
| 16 | |
| 12 | |
| 9 | |
| 7 | |
| 6 |
