Hi Experts,
Problem statement: I have a folder with 100+ reports and I need to do anlysis of which reports have same tables for which data is populated.
Example: I am taking 3 files (.xls) they are in a folder, I have only 1 row of data as data is not important but column headers are important
I need help to get to final Analysis as in picture. Sorry I cannot acces my GIT or any online links to send you files.
The example
1. Transaction.xlsx
2. SaleData.xlsx
3. Promotion.xlsx
The Interim Final Output, that might help me is this
1. Transaction.xls
2. SaleData.xls
3. Promotion.xls
In my work there are about 120 xls with different headers and format and data, I tried to upload from the folder and it got combined into a mess using Excel.Workbook([Contents]) 😞
The output I expect to transform to make a meaning is
Thanks in Advance
Regards
Source = Folder.Files("Complete Here With Your Real Folder Address"),
Custom1 = Table.FromRecords(
Record.ToList(
List.Accumulate(
Table.ToRows(Source[[Name],[Content]]),
(x,y)=>let a=Table.ColumnNames(Table.PromoteHeaders(Excel.Workbook(y{1})[Data]{0})),
b=List.Transform(
a,
each Record.FieldOrDefault(x,_,[])
&Record.AddField([#"Column Names/Data Tables"=_],y{0},"Yes")
in x&Record.FromList(b,a)
{"Column Names/Data Tables"}&Source[Name],
2
Custom1
@wdx223_Daniel Thanks a lot
It worked like charm in the example. It's a great help and I really appreciate your help.
Is it a great effort to add line to delete blank column in the source files ? I tried this on actual data, then I see two things
1. First row in some of the source files given to me were empty and some were good
2. There were some empty merged or hidden columns which are showing as column 1, column 10, etc
When I tried to remove them for a few files, the results are exactly what I need for my analysis.
Thanks a lot again
Thanks a lot again
For question 1, there must be some rules to identify which row is the header rows, then use Table.Skip function out of Table.PromoteHeaders. say, this first non-null value of column 1 is the header, then code like this
Table.PromoteHeaders(Table.Skip(_,each [Column 1]=null))
For question 2, if these column is useful, can find a way to define these columns and rename them. or just use if-then-else to skip them.
think you need show us more data to try.
Record.ToList(
List.Accumulate(
b=List.Transform(
a,
2
Custom1
| 3 | |
| 3 | |
| 2 | |
| 1 | |
| 1 |
| 9 | |
| 7 | |
| 3 | |
| 3 |
