Register now!Vote for your favorite vizzies from the Power BI Dataviz World Championship submissions. Vote now!
Hello!
I need help 😞
I have two tables. One with data with errors (let's call it table 1) (typos, mostly) and another with the correct information (table 2). I need to make a cross validation between the two tables, and when a value is table 1 is not on table 2, flag it (I tried with conditional formating, but it didn't work).
Does anyone have any suggestions?
Thank you in advanced! 🙂
Hi @liapimentaa ,
If you need to check the upper and lower case of a word's letters, try a merge query in Power query:
then crate a new measure like:
Measure = IF(ISBLANK(COUNT(Table1[Column1.1])),"yellow")
and use it as a background condition:
If you don't need to check the case of letters, you can try this one:
Measure =
VAR _cur_value = SELECTEDVALUE('Table1'[Column1])
VAR _count = CALCULATE(COUNTROWS('Table2'),'Table2'[Column1]=_cur_value)
VAR _result = IF(ISBLANK(_count),"yellow")
_result
Gao
Community Support Team
If there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly.
If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data in the Power BI Forum -- China Power BI User Group
Hi @liapimentaa ,
Measure =
_result
Gao
| 12 | |
| 11 | |
| 7 | |
| 7 | |
| 6 |
