Cross valiadation between two tables
- Anonymous2 years ago
Hi liapimentaa ,
If you need to check the upper and lower case of a word's letters, try a merge query in Power query:then crate a new measure like:
Measure = IF(ISBLANK(COUNT(Table1[Column1.1])),"yellow")and use it as a background condition:
If you don't need to check the case of letters, you can try this one:Measure = VAR _cur_value = SELECTEDVALUE('Table1'[Column1]) VAR _count = CALCULATE(COUNTROWS('Table2'),'Table2'[Column1]=_cur_value) VAR _result = IF(ISBLANK(_count),"yellow") RETURN _resultBest Regards,
Gao
Community Support TeamIf there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly.
If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!How to get your questions answered quickly -- How to provide sample data in the Power BI Forum -- China Power BI User Group
Hi liapimentaa ,
Measure =
_result
Gao
