I am attempting to create my first custom connection from an external electronic health program (using OAuth2) to power bi for visualization. The authorization process is complicated where I have to request and exchange a token each time it is accessed.
My end goal is to login to power bi, choose the custom connector and create a dashboard.
I have been unable to get my code to work. Visual Studios lists 0 errors, but when I run it I get the message " 0 arguments were passed to a function which expects 1".
I would like help clearing the error and any advice anyone can provide is appreciated. (full code is included below)
section Chrono;
Profile="AAAA";
Client_ID="XXXX";
Client_Secret="YYY";
redirect_uri="https://oauth.powerbi.com/views/oauthredirect.html";
token_uri="https://drchrono.com/o/token";
authorize_uri="https://drchrono.com/o/authorize";
logout_uri="https://loginmicrosoftonline.com/logout.srf";
scope="patients:summary:read";
error_description="Error authorizing application";
//Login modal window dimensions
windowWidth=720;
windowHeight=1024;
[DataSource.Kind="Chrono", Publish="Chrono.Publish"]
shared Chrono.Contents=(url as text) =>
source=Json.Document(Web.Contents("https://drchrono.com"))
source;
//Data source kind description
Chrono=[
TestConnection=(dataSourcePath)=>{"Chrono.Contents",dataSourcePath},
Authentication=[
OAuth=[
StartLogin=StartLogin,
FinishLogin=FinishLogin,
Refresh=Refresh,
Logout=Logout
Label=Extension.LoadString("DataSourceLabel")
//Helper functions for OAuth2
StartLogin=(resourceUrl,state,display)=>
authorizeUrl=authorize_uri & "?" & Uri.BuildQueryString([
response_type="code",
client_id=Client_ID,
redirect_uri=redirect_uri,
state=state,
LoginUri=authorizeUrl,
CallbackUri=redirect_uri,
WindowHeight=720,
WindowWidth=1024,
Context=null
FinishLogin=(context,CallbackUri,state)=>
//parse the full callback Uri and extract the Query String
parts=Uri.Parts(CallbackUri)[Query],
//if the query contains an "error" field, raise an error
//otherwise call TokenMethod to exchange code for an access_token
result=if(Record.HasFields(parts,{"error","error_description"})) then
error Error.Record(parts[error],"Error authorizing application:" & "s'" & [error],parts)
else
TokenMethod("authorization_code","code",parts[code])
result;
Refresh=(resourceUrl,refresh_token)=>TokenMethod("refresh_token","refresh_token",refresh_token);
Logout=(token)=>logout_uri;
GetChronoData = (ChronoId as text)=>
//https://drchrono.com/o/authorize/?redirect_uri=REDIRECT_URI_ENCODED&response_type=code&client_id=CLIENT_ID_ENCODED&scope=SCOPES_ENCODED
queryString=[
client_id = Client_ID,
scope = "patients:summary:read",
format = "json",
redirect_uri = "https://oauth.powerbi.com/views/oauthredirect.html",
code="GET",
response_type=":/api/patients_summary"
source=Table.FromRows(Json.FromValue(Web.Contents("https://drchrono.com/o/authorize/?redirect_uri=REDIRECT_URI_ENCODED&response_type=code&client_id=CLIENT_ID_ENCODED&scope=SCOPES_ENCODED",[Query=queryString])))
source;
GetChronoId = (profile as text)=>
source=Table.FromRows(Json.FromValue(Web.Contents("https://drchrono.com/o/authorize"))),
first=Table.FirstValue(source)
first;
GetResponse = (client_id as text)=>
//https://drchrono.com/o/token/
queryString=[
refresh_token="get_refresh_token()",
grant_type= "refresh_token",
client_id="XXXX",
client_secret="YYYY"
source=Table.FromRows(Json.FromValue(Web.Contents("https://drchrono.com/o/token/",[Query=queryString])))
source;
// Token method from Dr.Chrono "https://drchrono.com/o/token"
TokenMethod=(grantType,tokenField,code)=>
queryString=[
code="refresh_token",
grant_type="refresh_token",
redirect_uri="https://oauth.powerbi.com/views/oauthredirect.html",
client_id="XXXXX",
client_secret="YYY",
access_token="access_token",
refresh_token="refresh_token"
tokenResponse=Web.Contents("https://drchrono.com/o/token",[Query=queryString])
tokenResponse;
// Data Source UI publishing description
Chrono.Publish = [
Beta = true,
Category = "Other",
ButtonText = { Extension.LoadString("ButtonTitle"), Extension.LoadString("ButtonHelp") },
LearnMoreUrl = "https://powerbi.microsoft.com/",
SourceImage = Chrono.Icons,
SourceTypeImage = Chrono.Icons
Chrono.Icons = [
Icon16 = { Extension.Contents("Chrono16.png"), Extension.Contents("Chrono20.png"), Extension.Contents("Chrono24.png"), Extension.Contents("Chrono32.png") },
Icon32 = { Extension.Contents("Chrono32.png"), Extension.Contents("Chrono40.png"), Extension.Contents("Chrono48.png"), Extension.Contents("Chrono64.png") }
];Thank you,
KT
@ktroyerI'm trying to build a custom connector too, in my case, for Google BigQuery, but the Power Query SDK does not work on Visual Studio anymore. How are you building?
Thank you for responding Eyelyn, but the connector is not created due to this error, so it cannot be opened in power BI. In the Visual Studio the Error list says " No issues found", but when I run the connection I get the error 0 arguments passed to a function which expects 1.
Hi @ktroyer ,
According to this error message : " 0 arguments were passed to a function which expects 1", it means you used a function that should have one parameter, but you did not put any values in it.
For example,
I want to use Text.Length() to get the length of the column, but I did not put the column name, there will be such an error:
So please click the error / "Go to error" / check the error Details to find the error function.
Eyelyn Qin
