I am struggling with an issue and need your help. I cannot find any solution.
I need to create an index column with specific requirements. My dataset includes several columns, among them Client, Contract, User, and Equipment. For each client, I may have multiple contracts; for each contract, there may be multiple users; and for each user, there may be multiple equipments. What I need is to have an index column that counts how many contracts I have for each client.
Specifically, the index should start at 1 for each new client, remain the same if the contract doesn't change, and increment if there is a new contract within the same client.
Could you please help me with this?
Hi, @MenalM
Source = Your_Source,
Group = Table.Group(
Source,
{"Client"},
{{"Data1",
each Table.AddIndexColumn(Table.Group(_, {"Contract"}, {{"Data2", each _}}), "Index", 1)
Expand1 = Table.ExpandTableColumn(Group, "Data1", {"Data2", "Index"}, {"Data2", "Index"}),
Expand2 = Table.ExpandTableColumn(Expand1, "Data2", {"Contract"}, {"Contract"})
Expand2
Stéphane
Hi @Greg_Deckler ,
Thanks for your answer, but that's not what I need.
What I need is to reset the index for each new client, keep the same index within the same client if the contract doesn't change, and increment it if the contract changes.
It should work something like this:
| Client | ContIndex | CE MFG | Utilisateur | Serie |
| 1108 | 1 | 10444616 | P0010782 | YB50367U536837V |
| 1108 | 1 | 10444616 | S0017325 | CD4039D422219 |
| 42100 | 1 | 10266618 | P0005906 | 11836559 |
| 42100 | 1 | 10266618 | P0005909 | 1025 |
| 67000003 | 1 | 140819 | P0010354 | 1EZ17046 |
| 67000003 | 2 | 140820 | P0010354 | 536103381 |
| SK000008 | 1 | 10228719 | P0010262 | 535101200 |
| SK000008 | 1 | 10228719 | P0010262 | 5,36102E+13 |
| SK000008 | 1 | 10228719 | P0010262 | 63785. |
| SK000008 | 1 | 10228719 | P0010262 | 82433 |
| SK000008 | 2 | 123577 | S0020820 | 5306202480 |
| SK000008 | 2 | 123577 | S0020820 | CD4045B189216 |
Hi, @MenalM
Source,
{"Client"},
{{"Data1",
Expand2
Stéphane
Thanks for your answer.
This is an exemple of my input data :
| Client | Contract |
| Cl 1 | Cr 1 |
| Cl 1 | Cr 1 |
| Cl 2 | Cr 2 |
| Cl 3 | Cr 3 |
| Cl 3 | Cr 4 |
| Cl 4 | Cr 5 |
| Cl 5 | Cr 6 |
And my wanted output is :
| Client | Index | Contract |
| Cl 1 | 1 | Cr 1 |
| Cl 1 | 1 | Cr 1 |
| Cl 2 | 1 | Cr 2 |
| Cl 3 | 1 | Cr 3 |
| Cl 3 | 2 | Cr 4 |
| Cl 4 | 1 | Cr 5 |
| Cl 5 | 1 | Cr 6 |
I hpe this is now more clear for you.
Hi @MenalM
Follow these steps, make sure the Client column is selected
Choose Group By from the ribbon, set the operation to All Rows and and press OK
Go to the Add Column tab and Add an Index Column from 1
Final step is to expand missing fields, in this case Contract from the nested table.
Done.
I hope this is helpful
@MenalM Sorry, having trouble following, can you post sample data as text and expected output?
Not really enough information to go on, please first check if your issue is a common issue listed here: https://community.powerbi.com/t5/Community-Blog/Before-You-Post-Read-This/ba-p/1116882
Also, please see this post regarding How to Get Your Question Answered Quickly: https://community.powerbi.com/t5/Community-Blog/How-to-Get-Your-Question-Answered-Quickly/ba-p/38490
The most important parts are:
1. Sample data as text, use the table tool in the editing bar
2. Expected output from sample data
3. Explanation in words of how to get from 1. to 2.
