Register now!View all the Fabric Data Days sessions on demand. View schedule
Hi there - I am experimenting with imported semantic models. My assumption was that once imported they would behave in a similar way to referenced datasets and allow you to add new steps to the imported semantic model in Power Query. Is this possible in any way? I have had no luck so far.
Thank you in advance
No, I don't think you can enhance the Power Query steps of a referenced Semantic Model. It sounds like that is what you are asking. But in some cases, you can add additional Measures, etc. There are so many variations of how models and reports are configured that it is hard to keep them straight.
Proud to be a Super User! | |
Hi @headhoncho42 ,
Thank you for the accurate response @ToddChitt !
I am glad the suggested solution worked for you. If your issue is resolved, kindly accept @ToddChitt answer as a solution — it helps the community identify helpful answers more easily.If you still any issues, feel free to reachout!
Pallavi G.
Hi @ToddChitt - your solution matches my experience. I'll mark this thread as solved. Thanks for responding.
Thanks Tom - appreciate your answer.
| 10 | |
| 9 | |
| 6 | |
| 5 | |
| 3 |
