Power BI is hosted in AWS EC2 Machine and to access Power BI Service URL in dotnet and angular
Power BI is hosted in AWS EC2 Machine and we want to access Power BI Service URL in .net and angular applcation, but we are getting access issue. We have application id, workspace id, dataset id and report id of the Power BI, but we do not have application screte id to get access token. Can you pleaes help us how to get access token, application screte key,client id and access key to call the power bi service from .net and angular application.
Hi @Anonymous,
What type of dataset are you test? General dataset or push dataset? If you mean push dataset, please refer to the following tutorial document to know how to get the access token:
Get an authentication access token
If you mean the general dataset, you can check rest API document to generate the operation tokens: (notice: you need to register an application on azure side for permissions to use rest API)
Embed Token - Generate Token
Register an Azure AD application to use with Power BI
Xiaoxin Sheng
Hi @Anonymous,
Xiaoxin Sheng
Hi, Thank you.
I am able to generate access token in .net application after connecting to azure
Need Help -
 using (var client = new PowerBIClient(new Uri(ApiUrl), m_tokenCredentials))
// Get a list of reports.
var reports = await client.Reports.GetReportsInGroupAsync(WorkspaceId);
when i am fetching data for workspace, it is giving as unauthorized.
Error
            Status: Unauthorized (401)
Response:
RequestId: f9519e20-c04f-4488-aee1-9ca3be8b3326
 Please help me with your suggestion.
