Stharwani
Advocate II
Advocate II
Issues using Power query SDK in Visual Studio
I ma having issues using the Power Query SDK with the new update of Visual Studio. Anyone else facing a similar issue?
keithcaswell
I'm having the very same issue. I've uninstalled with no luck. Someone reported the issue on the github page. I hope that they fix it soon if it is a bug.
Atlsql
I'm having this issue as well, in both VS 2015 PRO, and VS 2017 PRO.
In attempting to self resolve, I've uninstalled the SDK from both 2015 and 2017.  Downloaded from the web, and downloaded from the marketplace from within Visual Studio.
Any thoughts?
I tried uninstalling and reinstalling a couple of times, but no luck. Did that work for you? @Atlsql
It is not easy to kill Visual Studio completely either.
It did not - truely appeared to be a bug.   (Glad I didn't completely uninstall and reinstall VS 2015 to try that fix).
Just saw a response on the GitHub issue from Matt Masson:
We're working on resolving the issue (problem with our build system) - hoping to have a fix out tomorrow night.
You are receiving this because you commented.
Data Days 2026
