Register nowThe Fabric community is upgrading! Read all of the details including the timeline and what you can expect. Learn more
Hi all,
I am new to power Bi embedded, basically i have followed the developer tutotorial and was able to successfully run the application in visual studio code Below is the screen shot.
I would like to know where i can insert below filter code. My apolgies, i don't have much developer backgroud.
Many thanks for your support.
Filter i want to copy:
const filter = {
$schema: "http://powerbi.com/product/schema#basic",
target: {
table: "Geo",
column: "Region"
operator: "In",
values: ["East"]
// Add the filter to the report's filters.
try {
await report.updateFilters(models.FiltersOperations.Add, [filter]);
console.log("Report filter was added.");
catch (errors) {
console.log(errors);
my existing JS code:
var reports = window.reports;
var datasets = window.datasets;
var embedToken = window.embedToken;
var models = window['powerbi-client'].models;
// Generate nav links for reports and datasets
$(function () {
var reportsList = $("#reports-list");
var datasetsList = $("#datasets-list");
if (reports.length == 0) {
reportsList.append($("<li>").text("[None]"));
else {
reports.forEach((report) => {
var li = $("<li>");
li.append($("<a>", {
"href": "javascript:void(0);"
}).text(report.Name).click(() => { embedReport(report) }));
reportsList.append(li);
if (datasets.length == 0) {
datasetsList.append($("<li>").text("[None]"));
else {
datasets.forEach((dataset) => {
var li = $("<li>");
}).text(dataset.Name).click(() => { embedQnaDataset(dataset) }));
datasetsList.append(li);
// Embed a report
var embedReport = (report, editMode) => {
// Create the report embed config object
var config = {
type: 'report',
embedUrl: report.EmbedUrl,
accessToken: embedToken,
tokenType: models.TokenType.Embed,
permissions: models.Permissions.All,
viewMode: editMode ? models.ViewMode.Edit : models.ViewMode.View,
settings: {
panes: {
filters: { visible: false },
pageNavigation: { visible: false }
extensions: [
command: {
title: "Show value in alert box",
selector: {
$schema: "http://powerbi.com/product/schema#visualSelector",
visualName: "bf36eb378296825d9db9" // Monthly sales trends
extend: {
visualContextMenu: {
// Get a reference to the embed container
var embedContainer = document.getElementById('embed-container');
// Embed the report
var embeddedReport = powerbi.embed(embedContainer, config);
// Add "Show value" context menu item
embeddedReport.on("commandTriggered", function (command) {
// Determine the command detail
var commandDetails = command.detail;
// If the command is showValue, show an alert box
if (commandDetails.command === "showValue") {
// Retrieve specific details from the selected data point
const category = commandDetails.dataPoints[0].identity[0].equals;
const value = commandDetails.dataPoints[0].values[0].formattedValue;
alert(category + " value is " + value);
// Embed the Q&A experience
var embedQnaDataset = (dataset) => {
// Create the Q&A embed config object
var config = {
type: 'qna',
embedUrl: dataset.EmbedUrl,
datasetIds: [dataset.Id],
viewMode: models.QnaMode.Interactive
var embeddedObject = powerbi.embed(embedContainer, config);
// Filter reports by product demographic
$(document).ready(function () {
$('#demographic').change(function () {
const report = powerbi.embeds[0];
const demographic = this.value;
const removeFilters = (demographic == "*");
const basicFilter = {
"$schema": "http://powerbi.com/product/schema#basic",
"target": {
"table": "Product",
"column": "Demographic"
"operator": removeFilters ? "All" : "In",
"values": removeFilters ? [] : [demographic]
// Update filters
report.updateFilters(models.FiltersOperations.Replace, [basicFilter])
.catch(error => { console.log(error); });
Project folder:
Hi @Nazim ,
You may refer to this offical blog: Control report filters
Code:
var accessToken = "@Model.EmbedToken.Token";
// Read embed URL from Model
var embedUrl = "@Html.Raw(Model.EmbedUrl)";
// Read report Id from Model
var embedReportId = "@Model.Id";
// Get models. models contains enums that can be used.
// Get a reference to the embedded report HTML element
var reportContainer = $('#embedContainer')[0];
if ("@Model.Username" != "") {
$("#RLS").prop('checked', true);
$("#RLSdiv").show();
else
$("#RLS").prop('checked', false);
$("#RLSdiv").hide();
if ("@Model.IsEffectiveIdentityRequired.GetValueOrDefault()" == "True") {
$("#noRLSdiv").hide();
$("#RLS").removeAttr("disabled");
$("#RLS").change(function () {
if ($(this).is(":checked")) {
$("#RLSdiv").show(300);
} else {
$("#RLSdiv").hide(200);
else
$("#noRLSdiv").show();
const testFilter = {
target: {
table: "SampleParameter",
column: "AgentID"
operator: "In",
values: ["H1627"]
// Embed configuration used to describe the what and how to embed.
// This object is used when calling powerbi.embed.
// This also includes settings and options such as filters.
// You can find more information at https://github.com/Microsoft/PowerBI-JavaScript/wiki/Embed-Configuration-Details.
var config = {
type: 'report',
accessToken: accessToken,
embedUrl: embedUrl,
permissions: models.Permissions.All,//models.Permissions.Read
//can add filters here
filters: [testFilter], //filter array here
settings: {
filterPaneEnabled: true,
navContentPaneEnabled: true //the nav at bottom of report
//filterType: models.FilterType.BasicFilter
// Embed the report and display it within the div container.
var report = powerbi.embed(reportContainer, config);
For refernece: Embed Report Filter not working
Rico Zhou
Hi @Nazim ,
Code:
else
} else {
else
target: {
column: "AgentID"
operator: "In",
values: ["H1627"]
var config = {
type: 'report',
embedUrl: embedUrl,
settings: {
Rico Zhou
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
| 2 | |
| 1 | |
| 1 | |
| 1 |
