How to get first instance based on multi criteria. I have shared excel formula to get and for reference.
Sample Data: Sample Data
Chandrashekar B
@Chandrashekar
Please refer to attached sample file. You need to addindex column using power query.
Result =
VAR CurrentIndex = 'Table'[Index]
VAR CurrentTable = CALCULATETABLE ( 'Table', ALL ( 'Table'[Index] ) )
VAR FilteredTable = FILTER ( CurrentTable, 'Table'[Index] <= CurrentIndex )
IF ( COUNTROWS ( FilteredTable ) = 1, 1, 0 )
@Chandrashekar
Result =
Thanks for the solution.
Hi @Chandrashekar
Can you attach a screenshot of the excel sheet along with the formula?
Please find attached excel data with Formula.
Sample Excel Data: Excel Sample Data
Chandrashekar B
| 19 | |
| 13 | |
| 10 | |
| 4 |
| 30 | |
| 27 | |
| 18 | |
| 11 | |
| 10 |
