Chandrashekar
Resolver III
Resolver III
indentify first instance based on multi criteria power bi
How to get first instance based on multi criteria. I have shared excel formula to get and for reference.
Sample Data: Sample Data
Chandrashekar B
tamerj1
@Chandrashekar
Please refer to attached sample file. You need to addindex column using power query.
Result =
VAR CurrentIndex = 'Table'[Index]
VAR CurrentTable = CALCULATETABLE ( 'Table', ALL ( 'Table'[Index] ) )
VAR FilteredTable = FILTER ( CurrentTable, 'Table'[Index] <= CurrentIndex )
    IF ( COUNTROWS ( FilteredTable ) = 1, 1, 0 )
tamerj1
@Chandrashekar
Result =
Thanks for the solution.
tamerj1
Hi @Chandrashekar
Can you attach a screenshot of the excel sheet along with the formula?
Please find attached excel data with Formula.
Sample Excel Data: Excel Sample Data
Chandrashekar B
@Chandrashekar
The link is not working
Can you check now pls.
Sample data: Sample Data
Chandrashekar B
