idontexist
how to check if current value more or less than previous power bi
Hi Power BI dax Gurus!
Got stuck with following thing - i need to check if previous value more or less than current. Example is below.
I have column "TDP growth" as value and column Date. Column "TDP growth conditional" should check if  current value more or less than previous.
TDP growthDateTDP growth conditional
91400001.01.20191
93200001.02.20191
97700001.03.20191
98400001.04.20191
97700001.05.20190
97500001.06.20190
97800001.07.20191
104800001.08.20191
107600001.09.20191
108600001.10.20191
113700001.11.20191
118000001.12.20191
Thank you!
idontexist
Guys,
You gave me an idea and i solved my request. Idea have following steps:
1. Create a measure that took previous value from same column.
    a. Here i need to create index column based on TDP growth
    b. Use a formula LOOKUPVALUE('KPI List v2'[TDP growth];'KPI List v2'[Index];'KPI List v2'[Index]-1)+0
Now i can get this:
2. Create new column that check if current value > than previous, using this formula: IF('KPI List v2'[TDP growth]>Column_new;1;0)
And all of this perfectly fit my demand.
Final formula (aggregated from two), looks like the following:
TDP growth conditional final =
var Column_new = LOOKUPVALUE('KPI List v2'[TDP growth];'KPI List v2'[Index];'KPI List v2'[Index]-1)+0
return
7 REPLIES 7
idontexist
Guys,
Now i can get this:
return
@idontexist   i think there is something summerezied in your table visual. because i have checked with the same dataset which you have given and it is exactly matching with your expected result.
Thanks & regards,
Pravin Wattamwar
www.linkedin.com/in/pravin-p-wattamwar
If I resolve your problem Mark it as a solution and give kudos.
check my blog here
https://community.powerbi.com/t5/Community-Blog/Connecting-to-a-Tabular-Model-Using-Power-BI/ba-p/91...
Hi @Anonymous
I found the problem why is that. Basically dataset in cube contains a lot more rows which are blank. This was not expected by me in initial request.
Attaching full extract.
OwnerAttributeTDP growthDate
Customer Service2019/06 2019/06
Customer Service2019/07 2019/07
Customer Service2019/08 2019/08
Customer Service2019/09 2019/09
Customer Service2019/10 2019/10
Customer Service2019/11 2019/11
Customer ServiceTarget
Finance2019/01 2019/01
Finance2019/02 2019/02
Finance2019/03 2019/03
Finance2019/04 2019/04
Finance2019/05 2019/05
Finance2019/06 2019/06
Finance2019/07 2019/07
Finance2019/08 2019/08
Finance2019/09 2019/09
Finance2019/10 2019/10
Finance2019/11 2019/11
FinancePY
FinanceTarget
FinanceYTD
HR2019/01 2019/01
HR2019/02 2019/02
HR2019/03 2019/03
HR2019/04 2019/04
HR2019/05 2019/05
HR2019/06 2019/06
HR2019/07 2019/07
HR2019/08 2019/08
HR2019/09 2019/09
HR2019/10 2019/10
HR2019/11 2019/11
HRPY
HRTarget
HRYTD
LegalPY
LegalTarget
LegalYTD
Marketing2019/01 2019/01
Marketing2019/02 2019/02
Marketing2019/03 2019/03
Marketing2019/04 2019/04
Marketing2019/05 2019/05
Marketing2019/06 2019/06
Marketing2019/07 2019/07
Marketing2019/08 2019/08
Marketing2019/09 2019/09
Marketing2019/10 2019/10
MarketingPY
MarketingTarget
MarketingYTD
MarketingPY
MarketingTarget
MarketingYTD
Sales2019/01 2019/01
Sales2019/02 2019/02
Sales2019/03 2019/03
Sales2019/04 2019/04
Sales2019/05 2019/05
Sales2019/06 2019/06
Sales2019/07 2019/07
Sales2019/08 2019/08
Sales2019/09 2019/09
Sales2019/10 2019/10
Sales2019/11 2019/11
SalesPY
SalesTarget
SalesYTD
Sales2019/019140002019/01
Sales2019/029320002019/02
Sales2019/039770002019/03
Sales2019/049840002019/04
Sales2019/059770002019/05
Sales2019/069750002019/06
Sales2019/079780002019/07
Sales2019/0810480002019/08
Sales2019/0910760002019/09
Sales2019/1010860002019/10
Sales2019/1111370002019/11
Sales2019/1211800002019/12
SalesPY746000
SalesTarget1000860
SalesYTD975000
Supply2019/01 2019/01
Supply2019/02 2019/02
Supply2019/03 2019/03
Supply2019/04 2019/04
Supply2019/05 2019/05
Supply2019/06 2019/06
Supply2019/07 2019/07
Supply2019/08 2019/08
Supply2019/09 2019/09
Supply2019/10 2019/10
Supply2019/11 2019/11
SupplyPY
SupplyTarget
SupplyYTD
SupplyPY
SupplyTarget
SupplyYTD
@idontexist
Measure =
VAR _prevdate = CALCULATE(MAX('Table'[Date]),FILTER(ALL('Table'),'Table'[Date]<MAX('Table'[Date])))
VAR _prevValue =  CALCULATE(SUM('Table'[TDP growth]),'Table'[Date]=_prevdate)
RETURN IF(MAX('Table'[TDP growth])>_prevValue,1,0)
Hi @Anonymous
Thanks for your help. Unfortunately, the same wrong result.
Create new column
Flag =
VAr Column_new = CALCULATE(MAX(Sheet1[TDP growth]),FILTER(Sheet1,Sheet1[Date]<EARLIER(Sheet1[Date])))
return
IF(Sheet1[TDP growth]>Column_new,1,0)
Thanks & regards,
Pravin Wattamwar
check my blog here
Hi @Anonymous
Thanks for help. Unfortunately it gives a bit wrong result.
