Don't miss your chance to take exam DP-600 or DP-700 on us!
Request nowLearn from the best! Meet the four finalists headed to the FINALS of the Power BI Dataviz World Championships! Register now
Hi Power BI dax Gurus!
Got stuck with following thing - i need to check if previous value more or less than current. Example is below.
I have column "TDP growth" as value and column Date. Column "TDP growth conditional" should check if current value more or less than previous.
| TDP growth | Date | TDP growth conditional |
| 914000 | 01.01.2019 | 1 |
| 932000 | 01.02.2019 | 1 |
| 977000 | 01.03.2019 | 1 |
| 984000 | 01.04.2019 | 1 |
| 977000 | 01.05.2019 | 0 |
| 975000 | 01.06.2019 | 0 |
| 978000 | 01.07.2019 | 1 |
| 1048000 | 01.08.2019 | 1 |
| 1076000 | 01.09.2019 | 1 |
| 1086000 | 01.10.2019 | 1 |
| 1137000 | 01.11.2019 | 1 |
| 1180000 | 01.12.2019 | 1 |
Thank you!
Guys,
You gave me an idea and i solved my request. Idea have following steps:
1. Create a measure that took previous value from same column.
a. Here i need to create index column based on TDP growth
b. Use a formula LOOKUPVALUE('KPI List v2'[TDP growth];'KPI List v2'[Index];'KPI List v2'[Index]-1)+0
Now i can get this:
2. Create new column that check if current value > than previous, using this formula: IF('KPI List v2'[TDP growth]>Column_new;1;0)
And all of this perfectly fit my demand.
Final formula (aggregated from two), looks like the following:
TDP growth conditional final =
var Column_new = LOOKUPVALUE('KPI List v2'[TDP growth];'KPI List v2'[Index];'KPI List v2'[Index]-1)+0
return
Guys,
Now i can get this:
return
@idontexist i think there is something summerezied in your table visual. because i have checked with the same dataset which you have given and it is exactly matching with your expected result.
Thanks & regards,
Pravin Wattamwar
www.linkedin.com/in/pravin-p-wattamwar
If I resolve your problem Mark it as a solution and give kudos.
check my blog here
https://community.powerbi.com/t5/Community-Blog/Connecting-to-a-Tabular-Model-Using-Power-BI/ba-p/91...
Hi @Anonymous
I found the problem why is that. Basically dataset in cube contains a lot more rows which are blank. This was not expected by me in initial request.
Attaching full extract.
| Owner | Attribute | TDP growth | Date |
| Customer Service | 2019/06 | 2019/06 | |
| Customer Service | 2019/07 | 2019/07 | |
| Customer Service | 2019/08 | 2019/08 | |
| Customer Service | 2019/09 | 2019/09 | |
| Customer Service | 2019/10 | 2019/10 | |
| Customer Service | 2019/11 | 2019/11 | |
| Customer Service | Target | ||
| Finance | 2019/01 | 2019/01 | |
| Finance | 2019/02 | 2019/02 | |
| Finance | 2019/03 | 2019/03 | |
| Finance | 2019/04 | 2019/04 | |
| Finance | 2019/05 | 2019/05 | |
| Finance | 2019/06 | 2019/06 | |
| Finance | 2019/07 | 2019/07 | |
| Finance | 2019/08 | 2019/08 | |
| Finance | 2019/09 | 2019/09 | |
| Finance | 2019/10 | 2019/10 | |
| Finance | 2019/11 | 2019/11 | |
| Finance | PY | ||
| Finance | Target | ||
| Finance | YTD | ||
| HR | 2019/01 | 2019/01 | |
| HR | 2019/02 | 2019/02 | |
| HR | 2019/03 | 2019/03 | |
| HR | 2019/04 | 2019/04 | |
| HR | 2019/05 | 2019/05 | |
| HR | 2019/06 | 2019/06 | |
| HR | 2019/07 | 2019/07 | |
| HR | 2019/08 | 2019/08 | |
| HR | 2019/09 | 2019/09 | |
| HR | 2019/10 | 2019/10 | |
| HR | 2019/11 | 2019/11 | |
| HR | PY | ||
| HR | Target | ||
| HR | YTD | ||
| Legal | PY | ||
| Legal | Target | ||
| Legal | YTD | ||
| Marketing | 2019/01 | 2019/01 | |
| Marketing | 2019/02 | 2019/02 | |
| Marketing | 2019/03 | 2019/03 | |
| Marketing | 2019/04 | 2019/04 | |
| Marketing | 2019/05 | 2019/05 | |
| Marketing | 2019/06 | 2019/06 | |
| Marketing | 2019/07 | 2019/07 | |
| Marketing | 2019/08 | 2019/08 | |
| Marketing | 2019/09 | 2019/09 | |
| Marketing | 2019/10 | 2019/10 | |
| Marketing | PY | ||
| Marketing | Target | ||
| Marketing | YTD | ||
| Marketing | PY | ||
| Sales | 2019/01 | 2019/01 | |
| Sales | 2019/02 | 2019/02 | |
| Sales | 2019/03 | 2019/03 | |
| Sales | 2019/04 | 2019/04 | |
| Sales | 2019/05 | 2019/05 | |
| Sales | 2019/06 | 2019/06 | |
| Sales | 2019/07 | 2019/07 | |
| Sales | 2019/08 | 2019/08 | |
| Sales | 2019/09 | 2019/09 | |
| Sales | 2019/10 | 2019/10 | |
| Sales | 2019/11 | 2019/11 | |
| Sales | PY | ||
| Sales | Target | ||
| Sales | YTD | ||
| Sales | 2019/01 | 914000 | 2019/01 |
| Sales | 2019/02 | 932000 | 2019/02 |
| Sales | 2019/03 | 977000 | 2019/03 |
| Sales | 2019/04 | 984000 | 2019/04 |
| Sales | 2019/05 | 977000 | 2019/05 |
| Sales | 2019/06 | 975000 | 2019/06 |
| Sales | 2019/07 | 978000 | 2019/07 |
| Sales | 2019/08 | 1048000 | 2019/08 |
| Sales | 2019/09 | 1076000 | 2019/09 |
| Sales | 2019/10 | 1086000 | 2019/10 |
| Sales | 2019/11 | 1137000 | 2019/11 |
| Sales | 2019/12 | 1180000 | 2019/12 |
| Sales | PY | 746000 | |
| Sales | Target | 1000860 | |
| Sales | YTD | 975000 | |
| Supply | 2019/01 | 2019/01 | |
| Supply | 2019/02 | 2019/02 | |
| Supply | 2019/03 | 2019/03 | |
| Supply | 2019/04 | 2019/04 | |
| Supply | 2019/05 | 2019/05 | |
| Supply | 2019/06 | 2019/06 | |
| Supply | 2019/07 | 2019/07 | |
| Supply | 2019/08 | 2019/08 | |
| Supply | 2019/09 | 2019/09 | |
| Supply | 2019/10 | 2019/10 | |
| Supply | 2019/11 | 2019/11 | |
| Supply | PY | ||
| Supply | Target | ||
| Supply | YTD | ||
| Supply | PY | ||
| Supply | YTD |
Measure =
VAR _prevdate = CALCULATE(MAX('Table'[Date]),FILTER(ALL('Table'),'Table'[Date]<MAX('Table'[Date])))
VAR _prevValue = CALCULATE(SUM('Table'[TDP growth]),'Table'[Date]=_prevdate)
RETURN IF(MAX('Table'[TDP growth])>_prevValue,1,0)
Hi @Anonymous
Thanks for your help. Unfortunately, the same wrong result.
Create new column
Thanks & regards,
Pravin Wattamwar
check my blog here
Hi @Anonymous
Thanks for help. Unfortunately it gives a bit wrong result.
| 5 | |
| 3 | |
| 2 | |
| 2 |
