I am facing an issue with calculated column.
This is sample data and here I want to achieve if isStoreClosed is Closed Status then I want to divide the Daily_Split Value by 6 and add this average value to the next 6 Retail Dates Daily_Split Value.
I have created the Daily_Split2 Column and written the folloing dax to achieve the result
hi @Anonymous
It would be good if you could simplify your case and provide the value of your expected column directly.
hi @Anonymous
try to add a column like:
Column2 =
VAR _lastclosedsplit =
MAXX(
TOPN(
1,
FILTER(
TableName,
TableName[Date]<EARLIER(TableName[Date])
&&TableName[IsClosed]="Closed"
TableName[Date]
TableName[DailySplit]
IF(
[IsClosed] = "Closed",
BLANK(),
[DailySplit] + DIVIDE(_lastclosedsplit, 6 )
)or
Column =
VAR _lastcloseddate =
MAXX(
FILTER(
TableName,
TableName[Date]
MAXX(
FILTER(
TableName,
TableName[Date]=_lastcloseddate
IF(
BLANK(),
it worked like:
hi @Anonymous
Column2 =
MAXX(
TOPN(
1,
FILTER(
TableName,
TableName[Date]
IF(
BLANK(),
)or
Column =
MAXX(
FILTER(
TableName,
TableName[Date]
MAXX(
FILTER(
TableName,
IF(
BLANK(),
it worked like:
How to solve this if the DailySplit is not the max number for closed dates @FreemanZ ??
hi @Anonymous
it shall still work, as MAXX here is actually calculating the max on a single value itself, filtered by the first argument of MAXX. Just give it a try.
Hi @FreemanZ , So in this screenshot if you see I have created a Daily_split 2 where I have divided the Value of Daily_split by 6 (Avg_Value) where isStoreClosed is in "Closed" Status which is Sunday
And now I wanted to add this value (Avg_Value) with the Daily_split value to the next 6 retail dates where the store is Open status and leave the row blank for "Closed" dates.
hi @Anonymous
| 10 | |
| 5 | |
| 5 | |
| 3 | |
| 3 |
| 24 | |
| 10 | |
| 10 | |
| 6 | |
| 6 |
